Hi all,
is it possible to have a MAC and CS from the flash and eeprom extracted with KTAG for a PCR2.1.
Thank you beforhand.
sorry for my English.
Thank
Hi all,
Thank
This type of ECU is protected. Did you use KTag ori or clone?
Hi, My ktag is clone. But i have already unlocked my ECU.
I need the PIN/CS and MAC to adapt with my AVDI because i don't have the AN057 licence in order to extract them
Cant be done such with SSM... cant, because need fullflash for MAC, CS or MCU ID.
So pcm flash is cheapest solution for. Other tools autotuner, magic motorsport, UDHS ...
You must have the Full Flash or CPU serial number from PRC2.1. The CPU Serial number can show You devices Like PolDiag(OVDT OBD Interface), MagPro, VagCanPro, PCMFlasher, MPPSv23(orig). Or You need to read the FULL Flah in BSL mode. The K-Tag, KESS and Galetto v54 can't read the FULL flash and show CPU SN.
need help
now my goal is to buy xp-005
who will help?
Thank you for quick responses.
I will try to find another solution in the one that you proposed to me.
Thanks again.
hi, sorry i still have a question. can we get the info from ecu with ODIS-E.
Thanks.
i can confirm that PIN/CS and MAC can not be extracted from the flash file that is posted in first post
