    Jul 2019
    Italy
    Default Iveco Daily Body Computer Marelli needs to be cloned
    I need to clone a bcm body computer marelli, but I don't know how.
    I've read around that i could do it with UPA (I have it genuine)
    These are references numbers:
    69502289 503440070208 NBCS20A.01
    Waiting for your help,
    best regards and stay safe!
    Tks!
    Jun 2012
    If you have used BCM 69502289 you only copy eep 95320.
    Iveco only.
  3. The Following User Says Thank You to greyg For This Useful Post:
    zzappy (14th April, 2020)
    Jul 2019
    Italy
    Quote Originally Posted by greyg View Post
    did you test it already?
    i mean do u have similar experience about this situation? i'm reading around on the web lots of info but it seems that the only tools can do this clone are i/o terminal or smoke, but both have problems with nec processor bcm. Or pin/carpass problems, or proxy alignment problems and so on...
    what i need to be sure is: do i need only to swap/copy 95320 then nothing else should be done?
    tks a lot for helping me mate!
    Jun 2016
    Everthing is in eeprom. Read eeprom and write eeprom. Just make sure u dont corrupt eeprom. So have knowledge of reading eeprom and u will be fine. Safe ori file for possible future use
  6. The Following User Says Thank You to Briankotze For This Useful Post:
    Jun 2012
    Quote Originally Posted by zzappy View Post
    Many times. Only BCM number is important. If there are any differences you have to combine content with eep.
    Iveco only.
  8. The Following User Says Thank You to greyg For This Useful Post:
    zzappy (15th April, 2020)
  9. #6
    ricked's Avatar
    Apr 2016
    Europe
    Tks!
    if you do much ofthis work buy io terminal, all can be done via connectors, and yes i use it and it works great
  10. The Following User Says Thank You to ricked For This Useful Post:
    zzappy (18th April, 2020)
