Results 1 to 2 of 2
    Apr 2019
    Default Toyota Prius 2006 AKL remote problem
    Hello!
    Did a all key lost on a Toyota Prius 2006 (made in mars 2006) with AVDI. Did not need to reset immo box, just programmed two new smart keys from Toyota with AVDI.
    Car starts with both keys but remote and keyless do not work (I have to put the key in the slot before pressing start button). Tried to add remote under function "main body", but it did not work. Find a manual way to program remotes online, open close door insert key and so on like on old Toyotas. When I did this the lock cycles two time to confirm that remote programming was not successfull.
    Any idea? What do I miss? Is not the remote programmed at the same time as transponer?
    (By the way, car have now 5 keys in memory, the first three one is lost)
    super jumbe's Avatar
    Livingstone
    Prius and Vorsa remotes looks the same recheck.
  3. The Following User Says Thank You to super jumbe For This Useful Post:
    mjoesen (18th April, 2020)
