Results 1 to 6 of 6
    Sep 2018
    Default PROBLEM WITH DQ200 SOFTWARE
    I use ktm flash to read eeprom and flash, can someone help me. I wrote the read files but as it is old dq200xx bone I imagine that is why the car does not recognize it.
    -The car uses a dq200xx.
    - I wanted to clone with ktm flash (dq200 MQB EEPROM and Flash).
    -The car doesn't recognize her.
    -I need Eeprom of a dq200xx and how could I write it
    ATTACHED THE FLASH AND EEPROM FILES THAT I READ WITH KTMFLASH, LEI ASI (DQ200-MQB)
    SOMEONE WHO CAN REVIEW WHY THE CAR DOES NOT RECOGNIZE THE DIFFERENCE IN A "DQ200XX"
    Newmotors's Avatar
    May 2019
    brazil
    so as not to have a problem friend, do it with vcds or odis
    Sep 2018
    Quote Originally Posted by Newmotors View Post
    THE PROBLEM IS THAT I HAVE ALREADY WRITTEN THE EEPROM WITH THE DQ200-MQB FILE AND I DO NOT HAVE A FILE WITH THE DQ200XX EEPROM
    Newmotors's Avatar
    May 2019
    brazil
    is dump file eprom
  5. The Following User Says Thank You to Newmotors For This Useful Post:
    sinue0007 (17th April, 2020)
  6. #5
    Sep 2018
    [QUOTE = Newmotors; 3848756] es un archivo de volcado eprom [/ QUOTE]
    THANKS I WILL TRY AND NOTICE
  7. #6
    Sep 2018
    this file is for dq200 0CW
    I NEED FILE FOR DQ200 OAM
