Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Dec 2018
    Guys, the car accept the new Kessy VDO-Siemens PIN Code but when i try to adapt it VCDS gives me "malfunction" :? Should I first make a key of the new Kessy VDO-Siemens and then to try to adapt it to the car :?
  2. #17
    dimon9555's Avatar
    Oct 2012
    Belarus
    By dump it is possible to adapt everything with old keys
  3. #18
    Dec 2018
    Can someone please put the old CS and PIN from Continental Kessy in the new VDO-Siemens Kessy. I think then the car will start working. I have tried to find it manually but couldn't see it Thanks
    Continental Kessy (old) - CS - EC 18 1C 70 C9 12 F8 PIN - 08984
    VDO-Siemens (new) - CS - E6 FE 95 6F 19 8D E5 PIN - 03784
    THANKS !!!
  4. #19
    ricked's Avatar
    Apr 2016
    Europe
    Quote Originally Posted by tyancool1995 View Post
    THANKS !!!
    your request
    btw your car will "not" start you need to addapt keys, immo + more...
    ask pass in pm only
  5. The Following 3 Users Say Thank You to ricked For This Useful Post:
    ASCM (25th May, 2020), immoneard (27th July, 2021), tyancool1995 (3rd May, 2020)
  6. #20
    Dec 2018
    I used your file and just changed the VIN and IMMO-ID manually and after adaptation of ELV the car started. Thanks to all of you.
  7. The Following User Says Thank You to tyancool1995 For This Useful Post:
    trinicolin (25th May, 2020)
  8. #21
    Apr 2014
    Very good feedback.
    Sent from my SM-G930F using Tapatalk
  9. #22
    ASCM's Avatar
    Oct 2018
    How did you changed vin and immo id
    And which tool u used for elv adaption?
    Sent from my SM-J415F using Tapatalk
  10. #23
    Jul 2019
    Quote Originally Posted by ASCM View Post
    VVDI2 dump tool will change VIN and ID.
    ADVI has EVL adaptation, it is free function.
  11. #24
    Dec 2018
    I used VCDS for ELV adapdation, but when i did it at 051 channel the success was after the 5th atempt. I dont know why. So you have to be patient . Yes, VVDI2 dump too can change VIN and ID also. The only question in my head is how mr. "ricked" changed the PIN and CS. Which tool did he use
  12. The Following User Says Thank You to tyancool1995 For This Useful Post:
    immoneard (26th May, 2020)
  13. #25
    ricked's Avatar
    Apr 2016
    Europe
    i did use brain.exe
  14. The Following User Says Thank You to ricked For This Useful Post:
  15. #26
    Jul 2019
    What did you put in New value at Ch51 ?
  16. #27
    Dec 2018
    1, just reLearned it
  17. The Following User Says Thank You to tyancool1995 For This Useful Post:
  18. #28
    Dec 2018
    I think so . so it is possible to see PIN and CS without convert the file :? Thanks
  19. #29
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by dimon9555 View Post
    This is not true.
    No one wrote the correct pin, because the correct 08984)))))
    How did decrypted the kessy continental
    To find the correct pin?
