Results 1 to 11 of 11
Thread: winols learning
    Dec 2019
    Default winols learning
    Hello.I try to learn winols.Can i find somwhere a quick guide for learning?Are there tips and tricks about tuning a map?Youtube is not so helpful.I dont want to be proffesional.I have winols and some maps for practice.Thank you in advance
    Apr 2020
    Arg
    Hi, I'm in the process of learning too, what I can tell you by far is that learning Winols is not the first thing to learn, it's just a tool (like others).
    First you should start by learning the different parts of a map, protocols read/writ, etc.
    Good luck!!!
  3. The Following User Says Thank You to JamboMan For This Useful Post:
    gpepes2012 (18th April, 2020)
    Dec 2019
    Thank you JamboMan.Are there any instructions to get started?The only thing i have found is the manual and some winols videos
    Apr 2020
    im also interested in learning winols. The tool doesent look complicated but i dont know how to find and identify maps.
    i also need this tool for windows 10. Can anyone share it?
    Hamo61
  6. #5
    Dec 2019
    i have winols 2.24 and its working perfect on Windows 10.
  7. #6
    dehacko's Avatar
    Feb 2018
    SK
    for beginer is better ecm titanium
  8. #7
    Stelaras26's Avatar
    Nov 2017
    Skyrim
    I ll try to make it Simple.You have the software.You have the drivers for the ecu file you want to make changes.You put the file inside winols,then software recognises different types of map then You make the changes in the maps you want
    Something like this
    If i Helped you,use thanks and rep button to thank me back
  9. #8
    May 2010
    Hello,
    it is hard to start learn in winols, but ecm it isn't enough complete.
    If you want make a good job, there is winols only.
  10. #9
    Mar 2017
    Portugal
    Hi everyone,
    If someone need it i've some video tut's for edc15,16 and 17..
    not much, cause i'm learning too but it helps to get started
    let me know if someone need it, i'll upload it and leave links here
  11. #10
    Apr 2020
    marko6jpt im intereset in the tuts. can you please upload it?
  12. #11
    Dec 2019
    Portugal
