I have a seat ibiza ASZ engine code, changed turbo for the PD160 one.
Done my file but need help to calibrate N75. What blocks should I read on vcds? How can I interpret those values?
Thanks for any help
Thanks for any help
this my file, n75 stock
ori file also
Search for bin file from cupra edc15p 1.9tdi 160hp and put in the car.
PRESS THANKS AND REPUTATION BUTTON IF I AM HELPFUL.
RoadBlock (21st April, 2020)
here you have ibiza pd 160 file...you can compare
log specified and actual boost, n75 duty cycle and rpm, from those info you can make neccessary adjustments
2WD Dyno , Magpro2 X17, FLEX Master , KESS Master , AUTOTUNER Master, Byteshooter Master, EVC Winols Reseller
Official Magicmotorsport DistributorCode:FILESERVICE: Tuning / DPF / EGR / Adblue / DTC / Immo
Official Autotuner Distributor
Official Alientech Distributor
advanced measuring block and select values i wrote above
Done some logs and attached.
Someone can help and point what all this data means or what to change...please.
Ok
Maybe someone could point in general, not for this case how this works?
What is there to point to? Actual boost should be as close as possible to specified
