Hi!
Please clear crash data.
Hi!
Hello to all. Here you go, press the thank you and rep+ buttons.
hamitie (22nd April, 2020)
Big thanks!
I'll try it tomorrow
I get this 2 error messages !!
The car has a left hand drive.
The configuration writes right-hand drive, and does not allow you to change it!
does anyone have an idea for this?
gm0frx16wqire6xp768l.jpgI
Hello to all. You will have to use diagbox ( only ), go in to airbag ecu and change configuration. After 2010 PSA group is protected by making changes to configuration from 3rd part users, but if you have good clone and latest soft you might do it. Is this the original ecu, or replacement?
hamitie (29th April, 2020)
Original ecu...
Hello to all. Config is change after crash repair by it self ??????????
Yes! .
Hello to all. Put back crash file and make a photo of errors, this is strange, this ecu is cleared like this many times before.
hamitie (26th May, 2020)
Hello to all. Here you have your file with 2 bits corrected( mist it on the firs time ) and second file from other car working ok with corrected vin number to match your car. Pass is the same. Will be waiting for result.
tomorrow night the car will come back. The day after tomorrow I will write the end result! thanks
Sorry I just checked in, but the car didn't come back just now. (Due to Turbo explosion)
The new VIN number dump is good!
Professional job!
Big thanks!
Eternal gratitude.
