Results 1 to 2 of 2
    Newbie fred988's Avatar
    Mar 2020
    Default FORD FOCUS EDC16C34-5.101 MICRO SC667034MPZ6 KTAG reading
    Hi everyone, I'm new to the forum, I wanted to share my experience in reading the Ecu in question. I had problems reading with both the KessV2 and the BDM100 (unofficial) .Probably because these last ecu of 2011 mount a micro different from the usual MPCXXX and there is not much information on the net on the interface suitable for this ecu.
    After the two attempts I tried with the Ktag and I managed to read the ecu.
    With the BDM100 I had soldered all 10 pins. Then I unsoldered the third pin. Although the Ktag instructions indicated an 8-pin adapter (without the third and fourth).
    I am attaching some photos of the connection with the Ktag, I hope it will be useful to someone !!!
  2. The Following 2 Users Say Thank You to fred988 For This Useful Post:
    LabraxDz (17th May, 2020), Talleresmalaga (26th April, 2020)
  3. #2
    Feb 2018
    ABYSES
    Thanks mate!! So useful, just a question about the protocol
    used to read with ktag 130? 140? Or 137? experiencing almost the same case with a Edc16c39 IVECO , SC667035MPZ eeprom95640. Thanks
