As the title suggest i just want to know if anybody still has uk virgin tv still working... I'm trying to see if its my setup at fault of if it has now gone dark?
Not sure of your set-up - but VM cable has been down for the last three days. Providers are working on a fix (some are back on line)
5 days ago the SD channels went missing, then the rest (HD) followed
lordtricky (24th April, 2020)
hi there, my setup is ubuntu server, tvheadend with oscam, dual dvb-c tuner and a single dvb-s2 tuner on a motorised dish. I still have 99% of my satellite channels but not a single virgin channel, oscam says the keys are found, but tvheadend says invalid start code.
You give me hope it is just a temporary problem.
Thanks for replying.
Assuming that you have your own card, then in config - Global in the box where it says - Skip CWs checksum test only for:
Enter the following and save
Code:0E00:000000;0500:050F00;098C:000000;09C4:000000;098D:000000;0500:030B00;0960:000000;1811:003311;1883:003311;1863:003342;1833:003311;1803:003343;1830:000000;1883:003311;1863:003343;1841:000000
plasterer (27th April, 2020)
Thank you for the suggestion but it hasn't helped the situation.
