Page 14 of 15 FirstFirst ... 49101112131415 LastLast
Results 196 to 210 of 222
  1. #196
    Dec 2023
    Hello friends
    I read a lot of posts here and ended up ordering what seemed to be the best package.
    I received this opcom which I am attaching to you in the following documents.
    in the ad, as it seems, there is no "D5 and C22" and on the back, the plate writes the date and the version.
    In what I received, everything is wrong, even the version in .
    unfortunately I placed the order without having an AliExpress account and now I can't locate either the ad or the seller.
    Can I work with this opcom? can i install it on win 10 or win 7 only
    I would like some help here1705560122046.jpg1705560122053.jpg1705560122058.jpg
  2. #197
    Nov 2017
    Dobruja
    The answer is clear. Is a bad clone. Use the sw provided by the seller. Other way, you will brick the interface. Drivers are working for win7 and win10 32/64bit.
  3. The Following 2 Users Say Thank You to volodin69 For This Useful Post:
    Mario6 (18th January, 2024), Tassoss (18th January, 2024)
  4. #198
    Dec 2023
    Quote Originally Posted by volodin69 View Post
    finaly i found the way to contact seller. i m waiting for an answer now
    to brick the interface you mean rewire same parts on the board?
    i saw same post below here
    any way, if seller doesn t anything good, i will search to try it
  5. #199
    Nov 2017
    Dobruja
    Brick comes from real word's sense, literally. Meaning it will block and become useless.
  6. #200
    Dec 2023
    Οk. My English isn't good. I understand you.
    Thanks a lot
  7. #201
    Dec 2014
    PL
    Quote Originally Posted by Tassoss View Post
    Thanks a lot
    Buddy, read post #182 again carefully and with understanding.
    This interface will support your Opel Vectra 2006 but you must use the software: "Opcom China 08.2010" or "Vauxcom 120309a".
  8. #202
    Dec 2023
    Quote Originally Posted by Mario6 View Post
    I will read the #182 post, but i can't find the numbers, thanks button, links and photos and others on my mobile device. I will do it an other day on laptop
  9. #203
    Dec 2023
    Yes, it's SW:"VAUX-COM 120309a+131223d GB". seller sent me cd for it.
    If can't return it, i'll try work with this, just only by included cd SW.
    Do you Know if works on WIN 10?
  10. #204
    Dec 2014
    PL
    Vauxcom 120309a works on OS WIN 10 64bit but very slowly. Better to use OS WIN 7.
    Older "SW Opcom China 082010" runs faster on OS WIN 10.
    It's enough for you.
  11. The Following User Says Thank You to Mario6 For This Useful Post:
    Tassoss (29th January, 2024)
  12. #205
    Jan 2024
    Guys, i've ordered a new unit as I need to reprogram my IPC panel. Now according to various sites there are 2 variants of Zafira B with no rec in tech2 choosing the wrong variant can cause stuff like rear wipers to not work, So my question is can this software correct this.
  13. #206
    Feb 2024
    Default Opcom
    Hello everyone, where can i download fantomels software package for opel. Can i have a link for download please?
  14. #207
    Jun 2018
    Thanks fantomel
    I have what seems to be a real pic it came with v1.70 and successfully downgraded to v1.67 an it is still working. I can read everything on my 2005 vectra c but on my astra j all the live data from the ecu can't be read. anyone got any ideas? Should i use a specific version of opcom or i must do the moding?
    Thanks a lot!
  15. #208
    Dec 2014
    PL
    Quote Originally Posted by capusopp View Post
    Thanks fantomel
    Thanks a lot!
    You can install and test all Fantomels Opcom versions. Then choose the one that is best and meets your expectations. However, you must remember that these are modified versions. Not original.
    They can be installed on one laptop. Preferably OS WIN 7 32 bit.
  16. #209
    Mar 2024
    I just bought one AE Opcom that seems to be using v1.70 but every time I try to use record option the software crashes, so I wonder what version addresses this problem. I opened the cable and this is what I found, it shows OPCOM_NEW and no C9 and D5 inside, but still not secure if I could go for 1.67 and if that would correct the problem with the record option. Thanks in advance guys!
  17. #210
    Mar 2024
    Ostrava
    Thank you very much. Wasn't able to download the text file (wanted ADV version), but received your soft with opcom clone...
    I have a HQ clone, works ok with 200603a - reading live data, able to program, firmware flash ok etc.
    Only thing which doesn't work is SWCAN. I found many posts regarding this on the internet, but no solution.
    The relay clicks once when connecting, but not the second time like still waiting for the answer. Do you maybe know what might be the issue? Same problem on fake china clone and 120309a+131223d > Also not reading SWCAN. Ordered opcom from idiag but it will take 4 weeks to come...
