Page 6 of 15 FirstFirst 1234567891011 ... LastLast
Results 76 to 90 of 220
  1. #76
    Jul 2021
    Thank you Fantomel.
    Asking for help from anybody.
    I've tested different soft versions up to 200603a_EN with op-com downgraded/upgraded from 1.99 -> 1.39 ->1.45->1.67
    and had troubles with getting live ECM Measuring Block - parameters:
    Motor type: Z18XER
    Part Number:55564081 (should be 75.5 with MAP + Air Temp)
    SIMTEC75
    1) In program I'm getting MAF (Mass Air Flow) with 0 values, instead of MAP (Air Pressure)
    2) When press 'Record' button the program crashes all the time (I've read to make LogFileViewer.exe compatible will try, isn't it for Viewing the Logs only ?)
    Best regards.
  2. #77
    fantomel's Avatar
    Mar 2009
    Us
    Quote Originally Posted by Ser9ei View Post
    Thanks, guys, for your feedback!
    I tested my OP-COM with the latest software ("OP-COM_200603a") and looks like it work.
    Could you please tell, is it possible upgrade my device according to the instructions from the "1.CH-CAN Support(REV.5 ONLY).pdf " manual?
    If your device is not a revision 5 PCB then that tutorial does not apply to you.
    If you know electronics and circuits then you can study the modification and also the interface diagram and then make a tutorial for other type of interfaces.
    If you like my post and it helped you please press THANKS.
  3. The Following 3 Users Say Thank You to fantomel For This Useful Post:
    Mario6 (2nd August, 2021), Sanyamaci (1st April, 2023), slobans (8th December, 2021)
  4. #78
    May 2021
    Latviа
    My opcom_new , the rest as in version 5.0 .
    Do not look at the white wire this board repair.
  5. The Following User Says Thank You to Olegs59 For This Useful Post:
    fantomel (12th August, 2021)
  6. #79
    Aug 2021
    Ukraine
    I have a opcom v.5 modified in Type C. I try to work with the program OP-COM_191022a_EN-Adv_v20830_Free4All.exe (190311a_EN-Adv) but it does not connect with any blocks. The program OP-COM_200603a_EN_Pro_v20830_Free4All.exe works well. Does "Advanced" work with Chinese opcom?
  7. #80
    May 2019
    Quote Originally Posted by fantomel View Post
    If you are curious open and see and you will not be sorry I always keep my word.
    And a little bit of help to see if your inteface is good or not.
    + I added down PDF's for CH-CAN modification and also if you like printed boards the project for it.
    Enjoy
    Fantomel
    I may be late to the party but thank you for your magnificent work. Works with OPCOM_NEW v1.95 and with both Astra J (in which I programmed Information cluster successfully) and with Insignia B (read and clear deep fault codes).
    Hopefully next versions would let us programm the Information cluster and maybe other options on Insignia B and newer models
  8. The Following 5 Users Say Thank You to bubimir13 For This Useful Post:
    bar7212345 (25th October, 2021), Mario6 (13th August, 2021), Sanyamaci (4th April, 2023), StefanS (13th January, 2022), Waclaw (13th September, 2021)
  9. #81
    Sep 2021
    Thank you fantomel!
  10. #82
    Apr 2020
    rar парола моля благодаря
  11. #83
    Apr 2020
    I downloade 150406d_EN 1.64 and asks for my password .pls password.
  12. #84
    Sep 2021
    How to download the .txt file?
  13. #85
    Apr 2021
    OP-COM odczyt kodu bezpieczeństwa / przepustki samochodowej / PIN
    Jak odczytać kod bezpieczeństwa samochodu?
    W załączniku przesyłam zdjęcia jak to wygląda w Astrze J.
    Dodam że w Astrze H lub Vectrze C po prostu klikam Security Code i wyskakuje jaki pin jest w aucie.
    W Astrze J, kiedy klikam Kod bezpieczeństwa, pojawiają się następujące okna.
    Nie wiem dokładnie, co tam kliknąć, żeby przeczytać kod. Czy możesz dać wskazówkę? pozdrowienia
  14. #86
    Aug 2021
    Anyone know which opcom version to use for CD40 USB? Always got this window(i select cd40 mp3 usb)
  15. #87
    Sep 2021
    i do have the 150406b and ask for registration-activation. help please!!!
  16. #88
    Dec 2014
    PL
    Quote Originally Posted by angiorgos View Post
    If it is Opcom 150406b from Fantomel, install the correct drivers.
  17. #89
    Sep 2021
    can you help me pleease with the drivers? i do have from fantomel
    but what i download is only one .exe. i don't see somewhere drivers
  18. #90
    Dec 2014
    PL
    Mate, the drivers are on the "C" drive - x86 program files, in the main Opcom folder. (DRIVER).
    Read the software and driver installation instructions.
    First Fantomel link.
    https://www.digital-kaos.co.uk/forum...ighlight=opcom
