Thank you Fantomel.
Asking for help from anybody.
I've tested different soft versions up to 200603a_EN with op-com downgraded/upgraded from 1.99 -> 1.39 ->1.45->1.67
and had troubles with getting live ECM Measuring Block - parameters:
Motor type: Z18XER
Part Number:55564081 (should be 75.5 with MAP + Air Temp)
SIMTEC75
1) In program I'm getting MAF (Mass Air Flow) with 0 values, instead of MAP (Air Pressure)
2) When press 'Record' button the program crashes all the time (I've read to make LogFileViewer.exe compatible will try, isn't it for Viewing the Logs only ?)
Best regards.
