zgemma forum?
Results 1 to 5 of 5
Thread: zgemma forum?
    May 2010
    Default zgemma forum?
    I used this site a lot when I had a dreambox and found the support and info priceless.
    However, since changing to a zgemma h2h there doesn't seem to be a dedicated part of the site for it.
    Any reason for this?
    plasterer's Avatar
    Jun 2008
    Mersyside
    wots prob with the h2h mate ..................Paul
    PAUL
    May 2010
    Hi Paul,
    You helped me out a lot with my dreambox some time ago, most appreciated.
    I have had no probs with the h2h, had it for a couple of years now and changed the software/images/ etc a few times without any hassle (mostly hehe).
    As there seems to be no active support for zgemma on DK , I used Tech Kings and downloaded DSayers images.
    All was going well, until last friday when slowly all the channels started to blackout, except FTA, and even then not all were working.
    I thought my line had expired, so I got hold of a new one from euroccam eventually, but no joy.
    Tried reinstallng everything factory reset etc., Tried installing wooshbuild... total disaster!
    After installation, I couldn't access any file through filezilla or anything else as windows decided I didn't have network security access!
    Seems wooshbuild has built-in security features.
    I could not bypass any of this, so couldn't get line into usr/keys!! aghhh!
    Reloaded old Dsayers image and all went well, but still back to FTA only.
    Weird thing is, when I do a full scan, 1100 channels are there, it downloads all epgs /summaries etc ok., no channels are greyed out.
    Tried to get another test line from euroccam but most providers don't even reply.
    Bearing in mind with my MS, leaping around pulling out plugs and USB sticks is a bit tricky .
    Any tips appreciated.
    I wondered if VM had got wise as they had with IPTV.
    plasterer's Avatar
    Jun 2008
    Mersyside
    Hi mate yes there were a few changes last week
    Will send you a pm.
    Like most forums mate traffics slow on here,(Unless you cars broke).
    But still some top blokes giving out great help as be for....Paul
    PAUL
    May 2019
    UK
    Just to add my bit -- as I understand it, until your server/supplier makes changes at their end, nothing you do at your end will help. VM have made some big changes
