Results 1 to 15 of 25
    Jan 2019
    Greece
    Default Flashed ecu smart 450
    Hello
    I went to write a mod file with the kess in an Smart 450 0,6.the ecu flashed and shows in the dash --------... I took out the eprom I wrote a file together with the flash (boot mode)I had backup with galleto 54 and it doesn't take my id in ecu data so it doesn't work in the car ... my ecu 0261205005
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    Quote Originally Posted by billys vtec View Post
    Hello
    you desolder eeprom...?
    for what...?
    if you have backup just write it, why you complicate...?
    Jan 2019
    Greece
    Desolder because galleto v54 says eeprom not writable.
    backup I have another ecu (eprom and flash) I wrote them but it doesn't work.
    I tried with the same software and different (always a pair of eprom and flash)
    Mar 2020
    write the flash eeprom from original second ecu as it was, and programming key to the car. the car will start
    Jan 2019
    Greece
    Quote Originally Posted by silver1 View Post
    I do this exactly but it doesn't work with the car ... and in my galletto it shows in ecu data (---------)
    if I transfer the eeprom flash from another ecu it works ... if I only transfer the files it only doesn't work
    Apr 2020
    post file whitch you have read from car, maby it is problem in file. In this ECU is 29F400 eprom. Probably you can use file version 1037351609, 1037351581, 1037351756, 1037351592, 1037351456, 1037351625, 1037351857
    Jan 2019
    Greece
    Quote Originally Posted by ZiZiTun View Post
    1037351756 bul i want and eprom 24c02
    figani's Avatar
    Feb 2018
    for what other eeprom...
    use or own one...
    itīs not otp tricore...
    find any 600 ccm flash equal which...
    and write and start car...
    and be happy...
    Jan 2019
    Greece
    I have written 3 different flash and the car does not work ... on eeprom on smart it also writes proportions for the gear changes ...
    figani's Avatar
    Feb 2018
    reallllllly....?
    what do you think why I write to you all time that you should write your own eeprom...?
    guess....?
    write your Eeprom and any flash...
    and connect ecu, and post what you get on dash when you give ignition...
    Jan 2019
    Greece
    Quote Originally Posted by figani View Post
    reallllllly....?
    guess....?
    Jan 2019
    Greece
    Does anyone have a virgin eeprom to try if it works ??? I have DAS for new ecu activation
  13. #13
    Jan 2019
    Greece
    use or own one...
    and be happy...
    write flash bootmode or desolder and write write with programmer????
  14. #14
    figani's Avatar
    Feb 2018
    as you want...
    is same...
    just write...
  15. #15
    figani's Avatar
    Feb 2018
    adapt key with das and adapt clutch...
    thatīs it...
    there is no need for virgin...
    its same...
    itīs all a 15 sec job...
