Page 2 of 2 FirstFirst 12
Results 16 to 29 of 29
  1. #16
    Nov 2019
    Will not allow me to upload pictures
    Code: p228c - fuel pressure regulator a exceeded control limits - pressure too low
    Additional fault symptoms:
    - missing calibration
  2. #17
    Dec 2009
    Portugal
    on the valve try to measure the resistance if it has 6 ohm is in order, with the plug disconnected.
    by the description of the fault it is lack of fuel, and it must give fault when you pull by the van.
    Anyway in my opinion you should try a new diesel filter.
  3. The Following User Says Thank You to rui For This Useful Post:
    Jamaly (2nd May, 2020)
  4. #18
    Jul 2013
    yorkshire
    Do these have a in tank pump?
  5. #19
    Nov 2019
    Hi replaced fuel filter today still same issue
  6. #20
    Meat-Head's Avatar
    Can you run it off external fuel can
    has some inbred crush fuel line?
    if you drive up/down your street like your stalking no throttle, just in 1 gear code?
    then if you drive it like your trying to get home to log on dk, does it cut dead?
  7. #21
    Dec 2009
    Portugal
    Did you come to do the regulator test if it is in order?
    Did you find small metal particles (filings) in the old filter?
    Before the repair, did he have this malfunction or did it appear now?
  8. #22
    Nov 2019
    Not done regulator test yet.
    Did not have this issue before went in for repairs.
    And code isnt present until i accelerate then goes into limp mode
  9. #23
    Jan 2010
    EU
    On the right side of the fuel rail there is the PRV - pressure relief valve - on this engines it always go bad an you will lose fuel pressure. When FRP is bad you cannot do any calibration because the rail pressure is alway changing.
    PRV is going bad when SCV - suction control valve goes bad. I suggest to check and replace both. You can check the PRV by simply remove the fuel return line from it and start the car, there should be no fuel running out from the PRV . ( Put the fuel return line in a bottle or fuel will run out everywhere)
    https://workshop-manuals.com/ford/tr..._relief_valve/
  10. The Following User Says Thank You to ollync For This Useful Post:
    Jamaly (3rd May, 2020)
  11. #24
    Nov 2019
    Hi that link refers to a 2006 van mines 2016 euro 6 is it ssme
  12. #25
    Jan 2010
    EU
    Sorry, didn't see year and engine. Tought it is 2.2 TDCI
  13. #26
    Nov 2019
    No problems is it same issue though as guys that apparently rebuilt engine changed fuel rail and injectors what they have told me
  14. #27
    Jul 2018
    Hi there, how did you fixed your problem coz i got a same one now after rebuild engine
  15. #28
    Oct 2015
    Hello. I have the same error, tried with original VCM II to reset but there is no option for that, only reset high pressure values which is for FRP only, not for regulator. How did you solve it?
    Sent from my M2007J1SC using Tapatalk
  16. #29
    Dec 2017
    Did you fix the issue at the end?
