Page 1 of 2 12 LastLast
Results 1 to 15 of 18
    Mar 2020
    Default Astra H 1.7 CDTI already tuned?
    Hello,
    Recently did a read on a friends car.
    I wanted to ask if someone could check if there is already a Stage 1 done because the car should have 110hp but feels pretty strong to me.
    Thank you.
    motor25's Avatar
    Dec 2015
    Belarus
    Hi! Its ori file, i try mod file to Z17DTJ +10 and +25, the effect is impressive)
  3. The Following User Says Thank You to motor25 For This Useful Post:
    audia4b7 (30th April, 2020)
    Mar 2020
    Thank you very much for checking!
    Maybe we try to tune it sometimes.
    motor25's Avatar
    Dec 2015
    Belarus
    I can do it!
  6. #5
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Quote Originally Posted by audia4b7 View Post
    Hello,
    Thank you.
    if you open it in ecm you would see that file is original from a 125cv car....... that's why is strong......
  7. The Following User Says Thank You to Panathaole For This Useful Post:
    audia4b7 (1st May, 2020)
  8. #6
    Mar 2020
    You are right.
    I just opened it in ECM and it showed 125cv.
    How can this be? Is it true if it shows that or maybe a mistake from ECM?
    In the vehicle registration it says 110hp...
  9. #7
    Panathaole's Avatar
    Oct 2017
    HELLAS - E.U.
    Maybe someone added to ecm database after tuning...
    To be sure make a diagnosis, find the s/w number and search for original to compare.....
  10. #8
    Mar 2020
    If someone could do a safe tune I would be grateful.
    It should have 110hp now according to the registration.
    Thanks.
  11. #9
    Aug 2018
    Austria
    Default Hello!
    Try this File and report!
    Pass after Thanks and Rep
    Greetings
  12. The Following User Says Thank You to Mariobozze For This Useful Post:
    audia4b7 (3rd May, 2020)
  13. #10
    Member lynexen's Avatar
    Aug 2010
    Sweden
    Question
    Hello,
    Thank you.
    Quote Originally Posted by motor25 View Post
    Quote Originally Posted by Mariobozze View Post
    Greetings
    Hi !
    I need help with a complete EGR delete of the whole EGR sytem in the ECU-box
    ( 2007 ) Opel/Vauxhall 1.7 CDTI ( 101 Hp. )
    Engine code: Z17DTH
    Can someone help ?
    .....A little more power would also be good if it's possible.
    Can someone help ?
  14. #11
    Baddog84's Avatar
    Sep 2012
    Germany
    how many posts do you want to make ??
    Quote Originally Posted by lynexen View Post
    Hi !
    Engine code: Z17DTH
    Can someone help ?
    Can someone help ?
    WinOLS 5, FGtech, Piasini, Powergate M, Byteshooter, OptiCan Dual II, EVC BDM, VCDS, BeeProg+,Ktag, Kess V3, Autotuner, Bflash
    Fileservice
    no thanks no pass
  15. #12
    Aug 2010
    Sweden
    Quote Originally Posted by Baddog84 View Post
    I'm a total newbie on computers
    But I have a friend that is a real master on computers.
    He also have VCX NANO to do some fault readings on GM cars and so on.
    Please explain in detail how to get a file and post it here ?
  16. #13
    migmig85's Avatar
    Jan 2018
    Poland
    You must have an interface that reads the flash from the engine ecu.
    If i can help you, press THANKS + REP !!!
    If you don't helping because like, only for money !!!
    Don't write in my thread !!!
  17. The Following User Says Thank You to migmig85 For This Useful Post:
    lynexen (24th May, 2020)
  18. #14
    Aug 2010
    Sweden
    Quote Originally Posted by migmig85 View Post
    You must have an interface that reads the flash from the engine ECU.
    Does a VCX NANO work for that ?
  19. #15
    migmig85's Avatar
    Jan 2018
    Poland
    No, VCX nano is only to diagnostic .
    You must be have kess, ktag, mpps or galetto interface .
    Best option is read on table always can you back to oryginal .
