Results 1 to 3 of 3
Hybrid View
    Nov 2011
    Portugal
    Lightbulb Checksum correction Denso ECU
    Hi guys.
    I have a 2008 Astra H GTC already modified.
    When I bought a Kess, I decided to read the Denso ECU of my car, but when opening the file in WinOLS, it gives me an error, with no checksums available.
    Recently with the help from annother user from this forum I was able to modify a bit more the file. He raisened some values and I tried to turn off the DPF.I opened the file in WinOLS to correct the checksum, and again, with no checksums available
    Can anyone help work around this problem?
    I'll Leave the files attached
    Original (the one from the car) and the other one with raised values and hopefully DPF off.
    Prichyndel's Avatar
    May 2012
    UK
    Kess does checksum from original file when writing. just write moded file and Kess will ask for original file,select the original file. will fix checksum.
    BR.
  3. The Following User Says Thank You to Prichyndel For This Useful Post:
    Cardoso85 (1st May, 2020)
    Sep 2013
    Arrow Checksum correction Denso ECU
    here your file with checksum
  5. The Following 2 Users Say Thank You to pike For This Useful Post:
    Cardoso85 (1st May, 2020), stanislav georgiev (1st May, 2020)
