Results 1 to 4 of 4
Hybrid View
    May 2013
    Hungary
    Default Toyota Corolla Verso 2.2 DPF EGR Problems
    Hi all!
    I need some support.
    Toyota corolla verso
    2005
    2.2 177hp
    SW: 89663-0F093
    Spare: 89661-OF090
    Engine: 2AD-FHV
    Short story:
    - Few years ago, Garage1 made this car EGR Off and stage1. Car working good!
    - Now, Garage2 made DPF off. Car now go Limp mode, max 2000RPM, not show DTC!
    So i think Garage2 use bad DPF off solution, or use Virtual read, and overwrite Egr and stage1.
    Help me please, i new ...
    This dupmp made by Ktag, please analys and correction.
    Thenk you.
    Jan 2018
    Jemen
    Swiftec solution. So disconnect the plug from the fifth injection and use a 1kΩ resistor.
    FILE SERVICE 24/7
    STAGE / DPF / FAP / EGR / SCR / NOx / TVA .. etc
  3. The Following User Says Thank You to oliva For This Useful Post:
    kroy0402 (3rd May, 2020)
    May 2013
    Hungary
    Test it soon...
    Thank you.
    May 2013
    Hungary
    Quote Originally Posted by oliva View Post
    Hi!
    Tested with 1K resistor, car running better, but limp mode come, but later.
    Info from car owner:
    - Egr blocked with plate (socket plugged)
    - DPF removed from car
    - New catalisator installed.
    On test drive, ~2500- 4000Rpm if push accelerator, car some noise "tztztztz"
    Like high pressure sound eruption.
    Thank you any help..
    Sorry my English..
