Results 1 to 8 of 8
    Default astra 1.6 8v z16se
    can anyone help with an original flash file for this car . astra g 1.6 8v with engine code z16se
    many thanks
    many many thanks
    peter
    I have some problems whith ecu too
    my car is an opel astra 2002 z16se
    this flash will work on my ecu?
    what sould I do too rewrite flash?
    thanks!
    you will need kwp2000 or galleto or similar to write this file to ecu
    I intend to buy kwp2000+ but my car "z16se" its not in the suported car list, should I buy it anyway?
    do I need "car pass" or any other code when I will rewrite ECU?
    can I save my map to change it lately if this one doesn't work?
    my car is in "limp mode" whith errors on TPS,TMP,IAR and EGR after someone changed my ECU.
    Thanks a lot! I think I'm on the right way!
    busaman's Avatar
    suffolk uk
    be careful guys you could end up with a dead ecu it doesnt read all of the map that way.
    @BUSAMAN
    what do you mean?
    how can I read all the map?
    busaman's Avatar
    suffolk uk
    tech 2 has the passthrough that you need to upload the complete file lik ( when you buy a new ecu with nothing on it) you can not load it via galetto or kwp2000.
