Any one got instruction how to programme Estima 7 seater 2002 remote, tried google but no joy, please need for Japan make otherwise this will not work the remote is 315MHz thanks.
Here is procedure to programm 2 button remote on jap toyota estima. If you have remote with only one button on side at step 10 press and hold this button for 3 sec, release, then press again for 1 sec.
Starting state:
Key out of ignition lock, Drivers door open, interior light on auto
Step 1: Key in and out of ignition lock 2x times (DON'T TURN !!!)
Step 2: Close and open drivers door 2x times
Step 3: Key in and out of ignition lock 1x time (DON'T TURN !!!)
Step 4: Close and open drivers door 2x times
Step 5: Close drivers door
Step 6: Insert key into ignition lock
Step 7: Turn ignition from lock to IGN & back to lock:
1x time for Add remote
2x times for Delete all remote and program new
Step 8: Remove key from ignition lock
Step 9: Locks will cycle to confirm program mode
Step 10: On remote press lock and unlock buttons together for 3 sec, release, then press and release lock button
Step 11: Locks will cycle if remote progamed
Step 12: repeat step 10 for any other remotes
Step 13: Open and close drivers door to exit programming mode
Good luck
super jumbe (6th May, 2020)
