I have a problem and I am turning on this forum for help.
I have mpps v16 connected to obd2 and connected to computer via usb, and the app. is showing error ( no external voltage found ) allso I am running it on virtual machine win XP.
Bad idea to use it on virtual machine
TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
SPECIALISE IN TUNING DIESEL ENGINES
(DEMON DEVELOPMENT)
IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
why? i have readed 3-4 times, and write modified files without any problem on XP SP3 on virtualbox Windows 10.
It's not as stable on virtual machine mabye you got lucky now you getting error possible cause is the virtual machine
(DEMON DEVELOPMENT)
Much thanks for your advice to not run it on virtual machine, but this was the most rookie mistake i made by not checking battery voltage.
