Results 1 to 15 of 25
    May 2020
    Default Hmm. Broken boot pinout on the ecu.
    Does someone know how to boot bosh edc17c10 when the boot place is damagde?
    some tips and tricks?
    Also need help to maybe clone a ecu.
    hit me up with a pm if you know your stuff
    carmageddon's Avatar
    Italy
    buy ktm bench (on aliexpress for example) and you can do boot r/w/chk without opening the ecu
    https://it.aliexpress.com/item/40003...c00qx90KX&mp=1
    May 2020
    I cant wait 3 weeks intill i get that system.
    is not another way to do it?
    Junkyard Dog's Avatar
    Mar 2019
    EUROPE
    Quote Originally Posted by Mauiii View Post
    Post here photos how is broken.
    May 2019
    On bench is build ecu of from car and pin out? with ktm bench alle ecu works?
    May 2020
    Im not getting connection to the boot pin.
    Mar 2019
    EUROPE
    Better quality photo
    Prichyndel's Avatar
    May 2012
    UK
    Easy fix if you are a micro solderer where u from ? i could help if u'r in the UK..
    May 2020
    Im from norway soooo ��
    Prichyndel's Avatar
    May 2012
    UK
    ...Pm sent..
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Clean track by scalpel and solder to it boot wire. Nothing to hard...
    heteromies
    Guest
    interesting, have same problem. How bootpin is made, layout? Goes throught PCB or how?
  13. #13
    Mar 2019
    EUROPE
    Quote Originally Posted by heteromies View Post
    You can connect on road what is going from boot pin
  14. #14
    heteromies
    Guest
    Quote Originally Posted by Junkyard Dog View Post
    Sorry, not got your point, not undestanding. Is there a way to find bootpin layout....?
  15. #15
    figani's Avatar
    Feb 2018
    47 45 52 4D 41 4E 59
    read post #11...
    itīs explained there...
