Results 1 to 13 of 13
    Nov 2008
    Default Vodka and Mgcamd
    Hello all
    Another newbie problem.. I am afraid.
    I just patched vodka v.0.0.2 for ipbox9000 on my Cuberevo twin-tuner HD.
    I could scan the cable channels, but can not watch anything but FTA.
    I FTP'd the Mgcamd 1.33 files, and made sure its config file is where it should be and what it should be as on previous threads on this site.
    I still have no joy.. and when I press the blue button,I can not see mgcamd there.
    Can anyone help please?
    Member grizzlyt's Avatar
    Oct 2008
    Quote Originally Posted by wahid View Post
    Hello all
    Have you given rights (Chmod 755) ?
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
    Nov 2008
    I am not the best in the Linux comands yet m8, but am working on it..
    How do I do that?
    aftermath's Avatar
    Mar 2008
    How do I do that?
    you will also need the nagra roms ( do a search on here for magic files "
    along with
    autoroll.key
    autoupdate.key
    softcam.key
    their should also be a mg_cfg ( thats if you installed the mgcamd config as well as the mgcamd 1.33 )
    if you right click on the mg_cfg and choose edit you will need to edit box type part to this for DGS based image. -
    # box type
    # 00 autodetect, change only if you think wrong type detected.
    # 01 dbox2
    # 02 dreambox
    # 03 triple-dragon
    # 04 relook
    # 05 openbox
    # 12 fortrex (ipboxhd)
    B: { 12 } i have known some people to change this to 00
    or this for E2 image :-
    # box type
    # 01 dbox2
    # 02 dreambox
    # 03 triple-dragon
    # 04 relook
    # 05 openbox
    B: { 11 }
    Nov 2008
    OK .. Thanks guys..
    Now every file transferred is Chmod755.
    Files are in the right place.
    I installed the mgcamd config as well as the mgcamd 1.33.
    mg_cfg file is edited as instructed, and box type is tried on both 00 and 12.
    Nothing happened..
    and when I press the yellow on the RC, I can see
    MultiCas
    Newcamd Client
    Cccam Client Then it has the following line underneath:
    Multicas or NewCamd executting...
    Still only FTA, with no change..
    Any other ideas?
    aftermath's Avatar
    Mar 2008
    OK .. Thanks guys..
    Nothing happened..
    MultiCas
    Newcamd Client
    Any other ideas?
    where are you located and what exactly are you using Mgcamd for ?
    Nov 2008
    HURRRAAAHHH
    I gave up on that vodka, so with Sifteam latest installed, auto mgcamd installer done, all channels are up and running on uk 6952. Pitty all the sat channels are Russians. It will take a long time to sort the Fav. folder, but that is the least of my worries.
    Thanks guys for all the help.
    aftermath's Avatar
    Mar 2008
    HURRRAAAHHH
    i dont bother with favourites as after time you remember what channels are on what sat.
    what do you mean , all russian channels ?
    glad you got sorted with mgcamd, i find it stops and starts sometimes, could just be my tuner though.
    Nov 2008
    Somehow when I installed the Auto Mgcamd, it installed saved fav. file that has every Russian channel on the plannet!!!
    I wish I can find a file from someone who is watching cable uk 6952 as well as standard sat for the south of England.
    I have a motorised dish 1.5 m and am not very much interested in any sats other than between 7 west to 28.2 east.
    i had problems with mgcamd also stop/start. installed camd3 and had no problems.
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by ianskill View Post
    mgcamd now is very stable and not stopping and starting, follow this and edit yours the same, this is for an E2 image. DGS based images only has 1 difference as explained above.
    Thanks to Jamie-warez for this.
    # EMM messages
    # 00 don't show any EMMs (default)
    # 01 show only valid EMMs
    # 02 show valid and bad EMMs with complete data display
    M: { 01 }
    # ECM messages
    # 00 don't show anything about ecm
    # 01 normal mode, show pids processed, decoded ecm and cw
    # 02 verbose mode, show valid and bad ECMs with data
    C: { 01 }
    # AU
    # 00 disable, no emm pids processed
    # 01 enable, emm pids always processed for soft-au and shared cards
    # 02 auto, emm started only if channel cant be decoded
    # 03 process emm pids for network cards update only
    A: { 02 }
    # key update (sum 01 or 02 with 04)
    # 01 update only new keys, default setting
    # 02 update all keys (used for valid PMK checking)
    # 04 enable TPS au
    # + tps SID, which pmt pid contains au pid
    U: { 01 } 0x12c0
    # config files folder (softcam, autoroll, ignore/priority)
    # 00 files in /var/keys
    # 01 files in /tmp
    T: { 00 }
    # network mode, use summ for several clients
    # 00 no network (default)
    # 01 newcamd netclient
    # 02 radegast netclient
    # 04 camd3 netclient
    # 08 gbox netclient
    # 32 cccamd netclient, card list saved as /tmp/cccamd.info
    # (ECM only, supported server version up to 2.1.1, later not work)
    G: { 33 }
    # network retry, use summ for several options
    # 00 disable
    # 01 retry every new ecm
    # 02 try to connect to offline shares every Q: seconds
    # 04 try to detect and fast reconnect to lost (and not used atm) server
    # + XX messages number and YY seconds to reconnect
    # mg will reconnect to server, if no answer to last XX ecm/keepalive or
    # if no answer for last ecm or keepalive sent for YY seconds
    # set to 0 to disable
    N: { 04 } 02 05
    # network ecm timeout in seconds
    K: { 01 }
    # newcamd dead routes connect retry, sec
    Q: { 60 }
    # network shares priority
    # 00 gbox, newcamd, cccamd, radegast, camd3 (default)
    # 01 camd3, radegast, cccamd, gbox, newcamd
    # 02 cccamd, newcamd, camd3, gbox, radegast
    P: { 02 }
    # on screen display type
    # 00 No OSD (default)
    # 01 neutrino
    # 02 enigma
    # 03 relook
    # + user password for http auth
    O: { 00 } username password
    # on screen display Options, summ of:
    # 01 show emu ecm
    # 02 show network shares messages
    # 04 show decoding failed / fta
    # 08 show emm keys update
    # + web port to use for osd
    S: { 03 } 80
    # Log option, summ of:
    # 00 off
    # 01 network udp log
    # 02 log to console
    # 04 file, appended ! delete it by yourself, before it eat all your hdd
    # + IP udp-port log-file-name
    L: { 03 } 172.16.1.1 28007 /tmp/mgcamd.log
    # keep ecm cache, seconds
    # every cache entry takes 28 bytes, so 24h cache will take *only* 240-400kb of memory,
    # for openbox/elanvision users with remote shares make sense to set it higher than default value,
    # to not hammer cards while timeshifting or playing crypted recordings.
    E: { 15 }
    # cache option, summ of:
    # 00 Off (default)
    # 01 Ecm pids cache, store pids used to decode in /tmp/ca_cache.list at exit, load at startup, same syntax as restore.list
    # 02 Ecm data cache, remember CW for (E time
    # 04 Emm cache for network cards, do not resend the same emm twice, cache not cleared until restart
    H: { 07 }
    # reread files, summ of:
    # 00 No (default)
    # 01 reread config file on channel change (including priority and ignore, but not replace/cache)
    # 02 reread SoftCam.Key on channel change
    # 04 reread SoftCam.Key if file changed
    R: { 00 }
    # debug, summ of
    # 00 off (default)
    # 01 debug ecm
    # 02 debug emm
    # 04 debug network ecm
    # 08 debug network emm
    # 16 debug network login
    # 32 show mem/cpu stats every 1 min
    # 64 add timestamp to log messages
    D: { 00 }
    # box type
    # 01 dbox2
    # 02 dreambox
    # 03 triple-dragon
    # 04 relook
    # 05 openbox
    # 06 dreambox/mips
    # 08 stapi/kathrein
    # 09 stapi/ipbox
    # 11 stapi/openbox
    B: { 11 }
    # map all 180x nagra caids to 1801
    # default is 01
    F: { 00 }
    Nov 2008
    Thank you
    I have followed that on couple of DGS images, but ended up in severe failure...!!!
    It looks like it is very sensitive to the version of CCCamd.
    My server uses 2.1.4, and it is, as written in the file, not supported beyond 2.1.1
    I just hope there will be a new Mgcamd support for the new Ccamd.
  13. #13
    Default Newbie Cube Revo twin cable tuner
    Hi Wahid, I'm new to Cuberevo hd twin cable and am having problems trying to sort-out what I need to do get my box working 'properly' as most posts are for satellite. From reading this thread it appears you have had the same problems but hopefully yours are sorted by now. Based on that assumption could you please simplify what I need to do/download to make it all work, a basics list would be appreciated if possible. I'm on V****n in the north of England on uk 6952 and as you can tell, a little basic with my knowledge of the subject.
