Hello here your data
I have a 2007 S5 in my workshop for a new key.
Normally I use VVDI2 and if that doesn't read them I use the file from VAG helper.
VVDI2 successfully disables security then either says it cant detect the key in the ignition or fails at the transfer data stage. VAG helper cant calculate this one and it gives me a 3 hour lockout from the server (I have tried twice). VVDI2 BDM cable wont read the NEC.
I have read the NEC and the 95320 with VVDI prog and comparing files from the forum the NEC data is identical so I believe the data is all saved in the 95320.
If someone can decrypt the 95320 I intend to figure out how the dummy files from VAG Helper work and inject the data so I can finish the job.
Part number: 8K0907289C
Chips: NEC 70F3239 and ST95320
Thanks in advance.
smokey08 (10th May, 2020), TERMINATOR1000 (10th May, 2020)
I have another S5 in my workshop, only difference is that one has a prox key. I have tried vag helper on that and that one fails with the same error.
Programmed first car with AVDI, did not try that at first because my ams has been expired for years and I thought it wouldn't work. Normally only get that out the box for old Audi TTs.
Obdstar also failed on it.
Sent from my Pixel 3 using Tapatalk
Hi. Try export function from vvdi 2, load flash and eep and vvdi2 sw will export file for add key.
Mate ,
Any chance you can help me with a decryption ?
Thanks in advance
Evernemi your eep is wrong read or very corupted.
Evernemi (20th May, 2020)
Done a read again mate
Apologies for that
Hi, possible calculate immo data A5 S5 BCM2 2008?
If I helped you know what to do..
Read nec in bcm
VIN: WAUZZZ8T18A045905
ECU CS: 1805ED7C300BD5809A6D2B0134AE3B28
KEY CS: 735C7653054FC2E60A9FBF35FD8F7E6B
Power class: C1
Key Count: 03
KEY 0: B5109F90
KEY 1: A11BB196
KEY 2: 3012B196
Hello, I have an Audi A5 with all the keys lost.
please can you calculate the immodata thank you very much
P/N: 8K0907289F
SW: 0253
HW: H38
VIN: WAUDK68T69XXXXXX7
KEY CS: 59C85A59657EC172CAFD169121882D22
ECU CS: DDE8A697BBD1497B97DCD2F72FE42D2F
ECU MAC: 1F43
TCU CS: 59C85A59657EC17B97DCD2F72FE42D2F
TCU MAC: 0582
ELV CS: DDE8A697657EC172CAFD16912FE42D2F
ELV MAC: 6C9E
BCM MAC: EAF7
Power Class: A5
Key Count: 03
Key 1: C2E99190
Key 2: F860C396
Key 3: A95FC396
davidjmj (9th March, 2022)
thank you very much brother.
With what tool can I load the key I have vvdi2
