windows doesnt works, central lock neither, engine fan allways on, car starts fine
checked all fuses all fine
no comunnication with a lot of modules
i changed confort module 3c0937049e with relay holder and its totally the same
Behind glovebox is convenience module. It seems fine no water corrosion, also door wires seems fine
Attach log
Quote:19 25 37 42 44 46 52 55 56 62 72 77
VIN: VSSZZZ1PZ6R068868 Mileage: 210920km-131059miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
52-Door Elect, Pass. -- Status: Cannot be reached 1100
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 EC HW: 028 101 176 5
Component: R4 2,0L EDC G000AG 8074
Revision: 12345678
Coding: 0050078
Shop #: WSC 06441 785 00200
VCID: 68884CE2FE704A67615-803C
2 Faults Found:
18107 - Powertrain Data Bus
P1699 - 000 - Missing Message from Steering Wheel Electronics
Freeze Frame:
RPM: 0 /min
Torque: 90.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.77 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 1.0
18043 - Powertrain Data Bus
P1635 - 000 - Missing Message from A/C Controller
Freeze Frame:
RPM: 0 /min
Torque: 90.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.77 V
Bin. Bits: 00001100
Bin. Bits: 00000000
(no units): 144.0
Readiness: 0 0 1 1 1
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 042 T HW: 02E 927 770 AE
Component: GSG DSG 070 1104
Revision: 04507000 Serial number: 00000601191363
Coding: 0000020
VCID: 241018D242D86E078DD-8070
1 Fault Found:
18275 - Powertrain Data Bus
P1867 - 000 - Missing Message from Steering Wheel (J527)
Freeze Frame:
Fault Status: 01100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 40
Mileage: 210921 km
Time Indication: 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AA HW: 1K0 907 379 AA
Component: ESP FRONT MK60 0102
Revision: 00H13001
Coding: 0006786
VCID: 71BE2186CDAA8BAF36B-8024
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags Labels: 3C0-909-605.lbl
Part No SW: 3C0 909 605 H HW: 3C0 909 605 H
Component: R3 AIRBAG VW8 027 2521
Revision: 09027000 Serial number: 003A1P1881Q/
Coding: 0021043
VCID: 2B02F3EE2F06A17F4C7-807E
Subsystem 1 - Serial number: 6332MSME0E613548
Subsystem 2 - Serial number: 6342MSME0E11496F
Subsystem 3 - Serial number: 6351HTS64IKAHQ53
Subsystem 4 - Serial number: 6361HTS63IKEM7F2
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
No fault code found.
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1P0 920 840 C
Component: KOMBIINSTRUMENT VO3 0518
Coding: 0006101
Shop #: WSC 07423 123 00816
2 Faults Found:
00457 - Central Electronics Control Module / BCM (J519)
004 - No Signal/Communication
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 F HW: 1K0 907 951
Component: Gateway H10 0120
Revision: H10 Serial number: 28001061068520
Coding: 7F3F03C8070202
VCID: 2A0CF6EA20FCB877B71-807E
9 Faults Found:
01331 - Door Control Module; Driver Side (J386)
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:28
01332 - Door Control Module; Passenger Side (J387)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:28
01333 - Door Control Module; Rear Left (J388)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:28
01334 - Door Control Module; Rear Right (J389)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:28
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:28
01320 - Control Module for Climatronic (J255)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:28
01336 - Company Data Bus for Comfort System
Freeze Frame:
Fault Priority: 1
Fault Frequency: 4
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:28
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:29
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 41
Mileage: 210921 km
Time Indication: 0
Date: 2000.00.00
Time: 04:34:29
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VO3 0518
Shop #: WSC 00000 000 00000
Address 37: Navigation
Cannot be reached
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-144-G2V2.clb
Part No: 1K1 909 144 K
Component: EPS_ZFLS Kl.5 D06 1701
VCID: 3332EB8EF736F9BF047-8066
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv.
Cannot be reached
Address 52: Door Elect, Pass.
Cannot be reached
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000009
Shop #: WSC 06403 785 00200
VCID: 74B02892B2B8BE87DDD-8020
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 77: Telephone Labels: 5P0-862-335.lbl
Part No SW: 5P0 862 335 B HW: 5P0 862 335 B
Component: FSE_2P5x H21 0060
Revision: 00000001 Serial number: 00000000375880
Coding: 0000555
VCID: 323CEE8A082CF0B70F1-8066
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 41
Mileage: 210921
Maybe one can convenience module is dropping can signal? Sony know what to do more
