Results 1 to 8 of 8
    May 2016
    Default BMW E87 EDC17 DPF Off
    Hello,
    I need DPF off from BMW E87 116d (2009my) in ECU:
    BOSCH EDC17 / TriCore / TC1766
    0 281 016 068
    DDE 8 506 281
    In attachment original files read by Ktag.
    Thank you in advance.
    Mar 2020
    i have good solution for you, tomorrow i can do if you wait
    Newmotors's Avatar
    May 2019
    brazil
    TEST DUMP FILE
    reported + thanks
    May 2016
    Unfortunately, your file not working...
    alexandrosts's Avatar
    Feb 2017
    there where civilization started
    here you go try this
    TO TUNE OR NOT TO TUNE
  6. The Following User Says Thank You to alexandrosts For This Useful Post:
    barylax92 (9th May, 2020)
  7. #6
    Feb 2017
    here you go new file checksum ok
  8. #7
    Feb 2017
    ok this file should fix the issue tested
  9. #8
    May 2016
    Now everything is OK, thank you very much!
