Can some one give me the key cut this car Auris 2007 thanks.
I think its 9 cuts I could be wrong.
Its 33423433
super jumbe (11th May, 2020)
IMG_4784[1].JPG Must be 8 cut
IMG_4785.JPGor 10 cut then 2334234332
I will cut tommorow I am 100% its 10 cut thanks Alpaholic.
Tried both cuts no joy and I now only got 1 blade left any one can check and give me the good cut thanks.
Did you force to turn the key in the lock a little bit? Put the blades together, are they similar? Wiggle?
super jumbe (13th May, 2020)
Made a grid...
Best to remove doorlock.
There is a gap, shim alignment is visable.
The code given, 23 34 23 43 32 50058 Toy43 appears correct.
Both door and ignition are giving you troubles?
Customer has posted the key and should receive one today will decode and let you know thanks for your time.
