Page 2 of 2 FirstFirst 12
Results 16 to 19 of 19
  1. #16
    Quote Originally Posted by Black Alien View Post
    Nope.... Starts and cuts... Shows 99 MIL immobilizer code
    Sent from my DUB-LX1 using Tapatalk
    Mate send Tiris format data from a 4C transponder i will send you a file ready to start your Car.
    Best Regards
  2. #17
    Talleresmalaga's Avatar
    Nov 2017
    Espaņa
    I wonder, because of my ignorance.
    and if the problem is not the files ?, with the immobilizer data removed
    Do I try with these files, recode the keys?
    This was not done, in other times, to adapt the ecu with immobilizer?
    Greetings
    If help is useful thanks+rep
  3. #18
    Nov 2017
    Espaņa
    Quote Originally Posted by Talleresmalaga View Post
    Sorry for the double posting,we proceed; if I don't forget anything
    connect the ecu and immobilizer, connect sbb, clear memory faults
    we restart the immobilizer, we program all the keys again, the ecu and the immobilizer are synchronized
    Greetings
  4. The Following User Says Thank You to Talleresmalaga For This Useful Post:
    Black Alien (17th May, 2020)
  5. #19
    Apr 2019
    BUENO DIAS TU PROBLEMA NO ES LA ECU ES QUE EN LA PARTE SUPERIOR DERECHA DE LA CAJA DE FUSIBLES DEVES REMOVER EL FUSIBLE QUE ESTA PUESTO EL AZUL Y CARGA EL ARCHIVO ORIGINAL Y ESO RESOLVERA TU PROBLEMA SUERTE
