I get Astra H with all keys lost, have new key and pin code. Where to add that key? In PEPS, in CIM, in both? Tried to read key info with VVDI key tool, but it cant recognise it, I can check remote only and its working.
Please help
Please help
p1et (14th May, 2020)
but where to add new key? CIM, PEPS or maybe both? with blade key - no problem, but this one is keyless
one more question. is there any chance to reset second hand key for opel keyless? i have some files for blade keys, but how about that one?
can I get info, please, about that procedure?
Finally done.
Procedure:
1. Read PIN using FVDI2018
2. OPCOM:
a. Enter immobiliser -> programming -> enter security code -> press start button
b. with ignition lights on, enter with OPCOM to PEPS -> programming -> programming -> enter security key
c. enter transponder learn mode. It will clear all keys
d. hold key next to transponder reading coil and press learn transponder
e. it will ask to press unlock button once, while holding to the coil
f. after successful learning, press display transponder info
g. if all OK, press close transponder learn mode
all working perfect
thanks for reply's
if this is helpful information to someone, please press thanks+reputation
autolocksni (16th January, 2021), castin (23rd October, 2022), dijo (23rd October, 2022), Faraday (24th October, 2022), joejam (22nd July, 2020), madaxe (1st July, 2020), Manta1600 (16th May, 2020), nenadgorgi (16th May, 2020), speedy100 (18th February, 2021), the_big_d (22nd October, 2022)
