Results 1 to 12 of 12
    Jun 2018
    Bulgariq
    Default DENSO DPF EGR OFF
    Hello friends I have the following problem with this DENSO car is mitsubishi pajero 3.2 did I tried several solutions for DPF EGR OFF but without success the problem is that the tube can not lift more than 0.4 boost can anyone help
    Sep 2013
    what solutions you tried?
    kris81orzesze's Avatar
    ireland
    Quote Originally Posted by naskochipa View Post
    tested file for that
    you can dysconnect sensors
    Csc Performance.
    Performance tuning file service.
  4. The Following User Says Thank You to kris81orzesze For This Useful Post:
    naskochipa (20th May, 2020)
    Jun 2018
    Bulgariq
    Quote Originally Posted by kris81orzesze View Post
    I tried your solution but it doesn't work, I turned off all the sensors and the car is even worse
    May 2020
    tot557545@gmail.com
    naskochipa
    hi collegue test my solution for dpf and egr off chk ok calculated....good day
    rep and thnx..........
  7. The Following User Says Thank You to ecuprogramer For This Useful Post:
  8. #6
    Jun 2018
    Bulgariq
    Quote Originally Posted by ecuprogramer View Post
    naskochipa
    Is your decision manual? and please send a password
  9. #7
    Jun 2018
    Bulgariq
    Sensors on or off???
  10. #8
    Jun 2018
    Bulgariq
    naskochipa
    Your decision does not work
  11. #9
    ireland
    Reset all adaptation on dpf by diagnostic, and the car has to drive and boost good even on the ori file, before pick up fault from missing dpf.
    Csc Performance.
  12. #10
    Jun 2018
    Bulgariq
    Want to upload an original to reset and drive until you record an error?
  13. #11
    ireland
    no just check if on ori is driving ok with power.
    Csc Performance.
  14. #12
    Jun 2018
    Bulgariq
    Yes, the car goes with an ori file but does not go with another file, there is no turbo
