hi.
I have ecu med17.2 from mini JCW.
Need change VIN from this ecu. Need put this Vin: WMWSV31010TY70541
I post files, read with ktag clone.
hi.
I change VIN.
But now car start but not accelerate. I do diagnostic and see 1 fault, dtc 3045 say: protection against tampering SWT: Engine-Speed Limitation, Stage 2.
any solution from this? I do reset ecu and not work
I post file I change VIN.
THanks
TY70541 does not seem to be a JCW? You need to load the normal Cooper S software.
If it is a JCW or you have bought the retrofit kit, you need to obtain the FSC code for that VIN and upload it to the ECU.
I change VIN.
And need checksum for work ok.
The orignal file is a TF78939
Thanks.
TY70541 is not jcw vin.So it will never work. It needs fsc.
Professional BMW immo solutions
Macedonia is one and GREEK!!!
and it's possible send me this FSC?
also generate me a DSC error code.
dtc is 5DE3 encodding error, and in dash iluminate abs lights. and also need change VIN number in DSC.
any help, please?
Thanks.
Can you just give some more information about the history and what you are trying to achieve? What happened to the old ECU? How did you synchronize the immobilizer?
Nobody will send you the FSC for the new VIN, it can only be generated by BMW and it costs € 2000,-. (You need to buy the JCW retrifit kit - Unless somebody already bought it for your specific VIN but it will have JCW badges all over the car)
Alternatively, you could change the VIN in the CAS and ECU back to the old VIN, so your entire car will have the VIN of the donor JCW.
But it is much easier to just program the Cooper S software. You can program it with WinKFP and then code the ECU with NCS Expert. If you want more power, you should ask someone to tune the original Cooper S software (I don't have much experience with tuning)
this mini original is a cooper S, but change engine and also change engine ecu, cas, kombi, dsc, etc
and need put the VIN number cooper S.
Thanks.
if it's possible help me for program with winkfp and NCS expert
Make sure you have stable power supply.
Start WinKFP -> Comfort Mode -> Enter ZSUB -> enter "7644424" -> Press Ok -> Enter full VIN -> Program
If it won't program because of incompatible hardware, use ZSUB 7644458.
If it can't find the ZSUB, you have different SP-daten than I have.
After programming, you have normal Cooper S software in the car and it should run fine.
You do need to code the ECU afterwards with NCS Expert to get rid of the "No coding" DTC.
serviclau (21st May, 2020)
i try and comment
thanks.
i try in two numbers, and two numbers say is icompatible hardware
any other idea?
Thanks.
