Page 2 of 3 FirstFirst 123 LastLast
Results 16 to 30 of 35
Thread: Mini JCW Ecu
  1. #16
    bearheroes's Avatar
    Dec 2011
    The solution is to keep ori cas and dsc. use ista and it will autodetect the proper sw for this ecu.
    Professional BMW immo solutions
    Macedonia is one and GREEK!!!
  2. #17
    Jun 2010
    Europe
    I didn't notice yet that you swapped an N18 engine for an N14 engine. You need the ZB-nr of an N14 Cooper S then.
    I always have trouble finding the correct ZB-nr for N14. Normally I would let ISTA/P do it but in your case (An N14 engine in a car that came with an N18 engine), that will not work.
    Try 8601564
  3. The Following User Says Thank You to tomvleeuwen For This Useful Post:
    serviclau (25th May, 2020)
  4. #18
    Jun 2010
    Europe
    Quote Originally Posted by bearheroes View Post
    If you keep everything original you can even keep FSC and have JCW software, but the JCW N14 VIN has to be in all modules. But apparently all modules were already swapped and he wants to change VIN.
    Forget ISTA, it will never work on a car with N14 engine but LCI radio, airbag module etc. This is just not a combination that is supported by ISTA.
    By the way, the DSC module just has to match the DSC sensor, but otherwise it can be swapped at random.
  5. #19
    bearheroes's Avatar
    Dec 2011
    Default Mini JCW Ecu
    Quote Originally Posted by tomvleeuwen View Post
    Never read that radio is changed. Ista p detects sw according to vo. In this case i think that something is not real. Anyway if all modules are from n18 then should just change vo from jcw to cooper s and use istaP. This is the best solution. Otherwise use cooper s ecu.
  6. #20
    Jun 2010
    Europe
    The point is that this 2011 car now contains an engine from 2007, so unless ALL modules from the 2007 car are used, (including radio, airbag, jbe etc), ISTA will never work.
    This car is a mess anyway, so why care about this little detail wheter ISTA can be used?
  7. The Following User Says Thank You to tomvleeuwen For This Useful Post:
    serviclau (22nd May, 2020)
  8. #21
    bearheroes's Avatar
    Dec 2011
    As he told me engine is jcw. I repeat thatsomething is not real.
  9. The Following User Says Thank You to bearheroes For This Useful Post:
  10. #22
    Feb 2010
    The problem is change engiine to jcw and all instalation.
    Then the owner tell me need change VIN because in chassis appears vin cooper S.
    Now I update all modules with winkfp, and when I update a CCC with number 9185624, now the display only appears mini logo and not start radio.
    THanks.
  11. #23
    Jun 2010
    Europe
    If the car has CCC, why would you ever want to have VIN WMWSV31010TY70541 in there? It's from an LCI without navigation...
    So we have the following VINs:
    Donor ECU: WMWMF91000TF78939
    New VIN: WMWSV31010TY70541
    What is the actual VIN of the car? Why do you want VIN WMWSV31010TY70541 in the ECU if the car is a pre-LCI with navigation??
  12. #24
    Feb 2010
    this VIN is from chassis and need put this.
  13. #25
    Feb 2010
    Hey.
    I try update engine controlo with this number:8601564
    And now accelerate ok and work, but also appear engine fault.
    It's possible this dtcs off for not appear in dash?
    Also, it's possible tell me a number for update a CCC, because now not work, appear only mini logo.
    Thanks.
  14. #26
    Feb 2010
    any idea for return work CCC?
  15. #27
    Jun 2010
    Europe
    The VIN you want to have in there is for an LCI without navigation, and you want to update the pre-LCI navigation. Something indeed does not sound very real.
  16. #28
    bearheroes's Avatar
    Dec 2011
    In this case vin has nothing to do. He tried to update cic( after 2010 no ccc) with k+dcan cable...
    Use icom with MOST adapter and winkfp expert mode.
  17. The Following User Says Thank You to bearheroes For This Useful Post:
    serviclau (27th May, 2020)
  18. #29
    Feb 2010
    not have icom.
    How program with winkfp in expert mode?
    Thanks.
  19. #30
    bearheroes's Avatar
    Dec 2011
    You can’t without icom. Impossible with kdcan cable. Anything else we say is waste of time.
