Results 1 to 15 of 17
    Jan 2017
    Netherlands
    Default W211 IM608 fails , question about keyless start with VVDI keys
    Benz W211 2002 - tried to add key. Could not do smart function, tried manual selection and expert but all no go. Won't even read EIS data except if I try EIS data using IR adapter. But that won't work for password so quite useless... Anybody any idea? Will do bench monday but would rather skip removing the EIS from this car (not that easy accessable). IM608 had connection with car, read gateway with VIN, etc. Abrites/AVDI could alsno not read EIS/EZS but I never used it so far in OBD situation so I don't wan't to put any conclusions to that (another heavy investment waiting to put to use, have to spend some time with it yet).
    Also... this car has a remote start button (besides standard IR slot) which works with same key. Will VVDI keys work with this system as well? Remote Start (just key in your pants, Mercedes had that long time ago already it seems). It's a W211 from 2002 (E500).
    Jul 2019
    I don't think VVDI key would work, it would not be able to be programmed since you still need to insert into IR slot during programming process. Their original key for the vehicle is still working?
    I would try AKL fast method with GBox if you have it. But if AVDI and Autel both fail, there may be another issue.
    Sent from my LYA-L09 using Tapatalk
  3. The Following User Says Thank You to madsci69 For This Useful Post:
    Matronix (17th May, 2020)
    Jan 2017
    Netherlands
    Might still be better to pull the lock then. Will have all the stuff with me monday so all options are open And yes, they had one working key, but FOB don't work, will test or this is remote issue or sync issue (or antenna, in the car, then the new key won't work either)
    Jan 2017
    Netherlands
    as an addition to my post I will share my findings for future use by others: This key is a little different to the ones I came across so far. It has no switches on the board, pushed / operated by the FOB press points. The switches are in the actual FOB casing and there is a fixed board with print lanes which are connected to the print board by the white plastic holding tab as found in all older Benz keys. Only this time, we have 4 guidance / connection points on this tab. This is prone of failure ofcours, the lanes in the key I have here are partially gone and the connections which go via the tab are bad as well. Looking up the number on the board in fob up on the internet gave me nada, zip, zero... so finding replacement parts seems to be a really hard to acomplish.
    This may also have been reason that the EIS data was not standard accessable, since it might be this system is just that little different. Might be we can make a key on the bench, but maybe it is even better to walk away and not temper with things that cannot be fixed afterwards due to a complete lack of info on this system (if it is that much different).
  6. The Following User Says Thank You to Matronix For This Useful Post:
    immoneard (19th May, 2020)
    Jan 2017
    Netherlands
  8. #6
    Jul 2019
    Quote Originally Posted by Matronix View Post
    Maybe it's fixable, but like anything it is taking a risk, since you're not able to add another key in.
  9. #7
    Jul 2019
    It is keyless key , I have seen it may times those keys. The thing is you can make regular key but keyless will not work, I do not think any of the aftermarket keys has keyless.
    Car is 2002 and that how keyless was in those car , at transmission shifter , not like new cars where ignition is with push button .
    And also I think no one make solution to renew used key.
    For make a key , best will be pull igntion and read hc12 Motorola with programmer, then you can make key very easy .
  10. The Following User Says Thank You to immoneard For This Useful Post:
    Matronix (19th May, 2020)
  11. #8
    Oct 2018
    Northern Ireland
    Would VVDI MB do this OBD or better on the bench ?
  12. #9
    Jan 2017
    Netherlands
    I just did the car using VVDI/ Abrites . On the car, but not OBD really. Used the IR adapter set and read EIS in about 10 secs. After that took 15 secs aprox to read password. Made the key with ProTagProgrammer in under a minute . Send several reports to Autel after they requested some tests. Propably getting back lots of new requests but this car will be back to it's owner so that will be a no go Autel...
  13. The Following User Says Thank You to Matronix For This Useful Post:
    immoneard (20th May, 2020)
  14. #10
    Jan 2017
    Netherlands
    start stop keyless needless to say that is a no go
  15. #11
    Jul 2019
    You must have Keyless key to be able to use that functions
  16. #12
    Jan 2017
    Netherlands
    indeed, but that I don't have and it's too rare to try and source it
  17. #13
    Jan 2018
    Where i can get a keyless Key for this car , i have the same issue , how to tell that the key has a keyless function
  18. #14
    Jul 2019
    Melbourne, Australia
    Quote Originally Posted by constantinexx View Post
    Old keyless like 211 it is best to find a second hand key from the same model and reset it. 03/08 ROM keyless is rarer and not really well supported in aftermarket.
  19. #15
    Jan 2018
    is there a way to reset it with the Autel IM508?<br>or other devices ?
