kenyon6 (18th November, 2021)
I have recently bought a Polo and I want to put it more power, like 140 Ps.
The first thing I did, was to put the FW back because of the Dieselgate problems. It had the 03L 906 023 MA 9978 fw and I flashed it back to 9971 with VAG Can Pro.
Since the car works a little bit smoother and has a very little bit more torque.
After I have unlocked the Siemens PCR 2.1 ECU and read it with Kess.
Now I have a problem.
I want to remap the file but I have not enough experience to work on it without map locations.
I have downloaded the famous Audi A1 map pack and tried to apply it to my file without success, because the maps are on different adresses.
I've tried to import the pack with offset correction without result.
Can someone give me the adresses or mod the file for me?
Like MARIOBOZZE, ho is a really good guy. He has remapped a 2.2 DTI Psg16 for me. It was a great job.
Here are the Id file and the Ori File.
Thank's
Pass Pm
Click Thanks and Rep
Remap (stage 1) / DPF / EGR / SRC/AdBlue / DTC off / VSA/Intake/Swirl flaps off / Lambda/O2 Removal/LSU / Start-Stop disable / Speed limit remove...
Thank you,
I will try the file as soon I can and take a report.
If someone else send me a mod file I will test it also.
So I have tried the file from brad123.
The car works fine. It have better response, particularity in the mid range.
Thank you.
Know I look for do the job myself, but there are too much maps and I didn't find those I have to work.
Is there someone here ho has a map pack or a damos for this file?
Is there no-one here ho can help me?
I need map adresses to modify, for my 03L906023MA file.
I have tried to compare my ori file and brad123 mod file, but there are too much changes and this will take a very big amount of time. I'm scared of single value maps.
contact with me
FILE SERVICE
Here, for MARIOBOZZ, my Passat files that I have Modded
