Results 1 to 11 of 11
    Mar 2016
    Default Jaguar XJ8 AKL and with replacement IMMO box
    Hi i've got a Jaguar XJ8 with immo box,
    locksmith stole customers immo box because he requested £1000 for key and told customer 150 on the phone, but spent 3 days and couldn't program key (shit people in this trade)
    im just trying to help the customer out,
    bought a replacement immo and im trying to make a key on bench, EEP is 93c46,
    VVDI failed to load the EEP with unknown version and tango loads the file but doesn't write keeps trying to write but failed with error to write.
    anyone can give me the T5 data so i can manually write it on the T5
    or any solution ?
    Kind Regards
    Mar 2016
    Or if any one can give me EEP data with T5 data so i can write it on and give it a try to make the vehicle start
    Meat-Head's Avatar
    Wont argue but think theres a simular thread from years ago see if anything useful in it
    Dec 2009
    scotland clydebank
    Are you sure are you using the right transponder and should have megamo id 48 not t5 as you requested double check it.
    Mar 2014
    West Sussex UK
    Quote Originally Posted by henal View Post
    or any solution ?
    Kind Regards
    Configuration : Megamos fixed - ID13 - JMA TP03
    Data : FF81 3434 ED14 2506 FF81 3434 ED14 2506
  6. The Following User Says Thank You to Cromwe11 For This Useful Post:
    henal (22nd May, 2020)
  7. #6
    Mar 2016
    Quote Originally Posted by Cromwe11 View Post
    Hi sorry would you be able to help me a bit more,
  8. #7
    Mar 2014
    West Sussex UK
    That’s the data to write to your t5 chip if it’s replacement immo box then it won’t be synced with ecu so easiest way is to fill eprom in ecu with all ff for it to run
  9. The Following User Says Thank You to Cromwe11 For This Useful Post:
  10. #8
    Mar 2016
    Hi, sorry for my lack of knowledge in this chip, but would it be FF 81 34 34 ED 14 25 06 to write to the chip since there is only 8 bits to fill in ??
    Kind Regards
  11. #9
    Mar 2014
    West Sussex UK
    2046B91982
  12. #10
    Mar 2016
    Guys i would really like to thank Cromwe11 for all his help. top man.
  13. #11
    Mar 2016
    2046B91982
    would you be able to explain this to me ?? how you came up with it ?
