Results 1 to 13 of 13
    Apr 2014
    Hualqui
    Default suzuki hdi 2.0 edc15c2
    Hello
    I need to delete the immo, I have tested a flash file but without results, I upload the dump of the eeprom 5P08.
    thanks in advance
    Aug 2016
    Hi there is your immo off done on your
    Apr 2014
    Hualqui
    Quote Originally Posted by joker007 View Post
    hello
    no work file
    mkii's Avatar
    Oct 2008
    immo off is in 29f400 not in 5p08 for 1 plug
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by mkii View Post
    no - correct off in flash and eeprom.................
    need help
    now my goal is to buy xp-005
    who will help?
  6. The Following User Says Thank You to rafal For This Useful Post:
    mkii (23rd May, 2020)
  7. #6
    mkii's Avatar
    Oct 2008
    Quote Originally Posted by rafal View Post
    thanks for the information.....We learn every day
  8. #7
    Philippines
    for bosch it is not necessary to touch 29f400 .. just eeprom is enough. checked 100 times .. it does the same as old PSA
  9. #8
    rafal's Avatar
    Jul 2010
    UK - PL
    Quote Originally Posted by camapa View Post
    your answer 50/50 is correct
    need help
    who will help?
  10. #9
    Apr 2014
    Hualqui
    you have a solution? flash or eeprom
  11. #10
    Feb 2018
    ABYSES
    Quote Originally Posted by perfido View Post
    I have a solution, only flash 29f400 poste the dump
  12. #11
    Apr 2014
    Hualqui
    Quote Originally Posted by LabraxDz View Post
    upload eeprom and flash ori
    thanks in advance
  13. #12
    Philippines
    I insist again. there I have made more than 100 ecu of these. there are several bosch references. your case is 0281010560. it is done with free inmokiller !! as any psa edc 15c2 (which can be done !!). You can even use any other ecu, for example from a xantia or a p306 etc. 29f400 ori + eeprom off and you have a vitara.
    otherwise if it were 0281011675 .. it would be another story
  14. #13
    Feb 2018
    ABYSES
    thanks in advance
    Here is you immoFF, try and report
