Dexxxx (6th July, 2020)
Hi friends ,can someone help with info for SeaDoo RXT 260hp 2012 year ? I have modded the maps of the rev Limiter, they were set to 8050 rpm , now setup to 8200. Also mod the Max Speed from 64 m/h to 80 m/h.
But rev limiter stays again limited to 8050 rpm, also very little increase of the max speed compared to ori maps. May be I owkn there is GPS like limiter for speed, but why RPM is not changed? Riva tuning offer GPS cheating module that increase speed limit, is this the only way to do this (beside the original BUDS2 with megatech key).
If someone has any info? Thanks and regards.
If helped, Rep and Thanks is highly appreciated!
Edit most types ECU eeprom mileage, hours,immo,mac,pin, etc..
Agro , Forklifts ,Boats ,Bykes ,Bulding mashines ,Body modules eeprom edit.
USA NGC3 NGC4 GPEC2 GPEC2A GPEC4 Stage1,MDS dtc egr cat evap off,all SeaDoo watercrafts limiters and tuning.
I use BitBox to read/write and BitEdit to change maps cheap solution I got first. Only thing you need to change manually (if you read flash via bootloader) is speed limit, search for FF FF 80 01 and change numbers before 00 00 00 00 to FF FF FF FF FF FF. I am switching to WinOLS as I use WinOLS now for Yamaha and other ECUs.
quato79 (20th October, 2020)
Yes,thanks, I got them both + ECM, now evrything is fine.
regards
