Hello !
If 2 ecu board is some only copy from the original ecu st10F280 internal flash and external eep (i dont know is 95040 or 95080 ) data to used ecu .
And don't need anything , car starts without any problem .
BR
- Hello,first of all bear in mind this is my first try on cloning Ecu.Sorry if I sound silly.
- I have 2 Identical ecus Delphi DCM 1.2 8200399038/8200513163.One is from Micra 1,5Dci and one from Note 1,5dci.
- I've read with Galleto in boot mode the St10f280 flash.I will also have to find and read the eeprom(using programmer) and then write it to the donor ecu?After that I've read that i have to code the injectors.Guess I ll do it with Consult 3 plus.Other than that will i have any problems with the car vin number?
- Is it better if i Virginize the eeprom from the donor ecu and put in in the car ? Will i have any problems with the maps of the cars since these are 2 different cars with the same ecu?
Hello !
BR
KangaroSalesman (21st May, 2020), Louislesinge (21st May, 2020)
I see,
So I guess if the ecus are exactly the same,it doesn't matter if the one is from a Nissan Note and the other from a Nissan Micra as long as you copy both flash and eeprom.
Thank you !
Yes , if 2 ecu hardwere is same only software different .
antonypaul (6th June, 2022)
