Results 1 to 8 of 8
    Member autoperfect's Avatar
    Sep 2009
    Default iaw 4lv immo off
    heyy
    i need off for this file :
    eeprom 95080iaw 4LV.N
    036906034 M
    golf 4 1.6
    Feb 2013
    North of the South, Venezuela, self-exiled in D.R.
    your file can be bad reading, please verify
    I sent this file please test and comment
    password by pm
    Iplease Thanks and rep.
  3. The Following User Says Thank You to aquilesy For This Useful Post:
    autoperfect (26th May, 2020)
    Sep 2009
    hi
    not working
    i need a virgin eeprom fil for iaw 4lv golf 4 1.6
    part number :036906034M
    thank you
    Feb 2013
    your original file is bad, test this file,100 % good new eprom immo off, please comment your problem
  6. #5
    Feb 2013
    Brother, you can test this eprom, pin is 0104
  7. #6
    Sep 2009
    all the files are bad or not match with the ecu*
    i need pin code from this file to test it
  8. #7
    Feb 2013
    immo code 0102
  9. #8
    Aug 2009
    For this type of ECU if you want to make Immo OFF I recommend you to use emulator inside ECU.
    This way is always 100% Immo OFF. And there are very cheap emulators for these on Ebay, etc...
    Also, I normally cut K line + W line on instrument cluster to make sure it donīt send Immo data at same time as emulator to engine ECU.
    If I helped you please press Thanks + Reputation.
