Page 1 of 2 12 LastLast
Results 1 to 15 of 19
Thread: EZS Stolen
    Aug 2011
    Default EZS Stolen
    hi all i have a 2010 vw crafter
    the ezs has been stolen i have a new unit can some one guide me to whats the procedure to adapt a used ezs i have vvdi prog and VCDS
    Have read out Pin from ECU but need the Pin from the new ezs to adapt for car. channel 50
    Have read out the 9S12 on the new ezs but can not decode the information.
    Here you have the files from the ezs and the ecu .
    hi there the Mask is : 1L15Y ID:411
    Best Regards
    The part number for the eis is
    vag number 2E0905843D
    Mercedes number on che same eis is 9069003803
    Per
  2. The Following User Says Thank You to digitaleksperten For This Useful Post:
    rob h (24th May, 2020)
  3. #2
    rob h's Avatar
    May 2011
    Your ezs dump, there is no pin and cs.
    How did you read it?
    Make sure that the wires you solder on the pcb, dont touch any other parts on print!
    Easiest way, to to get the car running, is immo off, and a elv emulator.
    whiskeyman's Avatar
    Dec 2010
    where men are men and women eat their babies
    why is it i am starting to see a trend in stolen ezs??
    Aug 2011
    The ezs is brand new from vag have read it with vvdi prog. try to adapt it with VCDS go in to immobiliser and adapt for car have org pin from ECU 03960
    I was just thinking that they have put 12345 or 00000 01231 in the ezs so when i adapt it i have to put the original pin and then the pin is has to be ?.
    The data i have read out from ECU.
    Pin number 03960
    CS : 71A3B925CF353F
    MAC: 7763911A
    Best Regards
    Per
  6. #5
    Meat-Head's Avatar
    Quote Originally Posted by whiskeyman View Post
    There like £500 understand
  7. The Following User Says Thank You to Meat-Head For This Useful Post:
    doctore (24th May, 2020)
  8. #6
    Mar 2016
    Quote Originally Posted by digitaleksperten View Post
    Best Regards
    Per
    send me the full part number and the whole Flash and EEP of the virgin EIS, i will compare and add the data to it.
  9. #7
    rob h's Avatar
    May 2011
    If you find someone with a online vag account, it should be easy.
    And please do post the ezs flash, it would really help others out.
  10. The Following 2 Users Say Thank You to rob h For This Useful Post:
    ASCM (24th May, 2020), doctore (24th May, 2020)
  11. #8
    ASCM's Avatar
    Oct 2018
    Pin number 03960
    CS : 71A3B925CF353F
    MAC: 7763911A
    Best Regards
    Per
    Hello can you post flash data and part number of esz?
    Sent from my SM-J415F using Tapatalk
  12. #9
    Feb 2010
    Hungary
    Try this eprom and flash and collect!
    Power class FE
  13. #10
    Aug 2011
    Hi i have changed my original oplade with all data
    Best reagards
    Per
  14. #11
    Aug 2011
    Hi now i have flash the eeprom but when i try to flash the flash the program says
    Chip crack failure, please confirm the chip type and connection right, then try again !
    No it is not possible to rewrite the old eeprom data back again because is says the same
    It looks like the password is changed in the eis )EZS modul now the vvdi prog can not hack into the modul any more
  15. #12
    Feb 2010
    Hungary
    I remember, vvdi not select good this mcu, select manual 1l15y secured 9s12dt384 or read id and select it, your ezs read in not good dump
  16. #13
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by leaserhu View Post
    As i know this bug its corrected in the latest tool update
  17. #14
    rob h's Avatar
    May 2011
    To be sure, selected other reading options.
    There are 256 384 and 512 flash sizes.
    0L01Y MC9S12DT256_0L01Y
    Mask:0L15Y ID:C410
    Mask:1L15Y ID:C411
    Mask:0M23S ID:C412
    1L15Y 512
    vvdiprog only lists the 384 and 512 in immo vw section
    256 in immo benz section.
    Only when you are sure, you start writing anything.
    I prefer Rosfar, or even Orange5, still not vvdiprog on eis.
  18. #15
    ASCM's Avatar
    Oct 2018
    Quote Originally Posted by rob h View Post
    Mask:0L15Y ID:C410
    Mask:1L15Y ID:C411
    Mask:0M23S ID:C412
    1L15Y 512
    Which version of rosfar use ?
