edc16c34 fap off 206 hdi
Results 1 to 7 of 7
    Sep 2019
    rennes
    32
    Downloads
    Uploads
    Default edc16c34 fap off 206 hdi
    can someone help me dpf off with dtc off for my car peugeot 206 1.6 hdi 110cv edc16c34
    dtc :
    P1446
    P1445
    P1442
    Thanks in advance
    ivanmihov's Avatar
    Nov 2016
    Bulgaria
    116
    Downloads
    23
    Uploads
    your file pass in PM
  3. The Following User Says Thank You to ivanmihov For This Useful Post:
    diagoto44 (23rd May, 2020)
    May 2016
    59
    Downloads
    3
    Uploads
    Your file dpf dtc off.
  5. The Following User Says Thank You to naprawa5 For This Useful Post:
  6. #4
    Sep 2019
    rennes
    32
    Downloads
    Uploads
    Hello guys.
    I have a problem with the additive system light that appears on my dashboard
    @ivanmihov, i have one dtc P1446, I erased the defects but it comes back. I reintialized with diagbox the additive level with the additive ecu system
    @naprawa5, I have none dtc, I reintialized with diagbox the additive level with the additive ecu system
    I handed the original dump and then I reset the additive level to zero, the message always appears
    I don't know what to do?
    May 2016
    59
    Downloads
    3
    Uploads
    Disconnect additive ecu.
  8. #6
    Sep 2019
    rennes
    32
    Downloads
    Uploads
    I have to unplug the connector. and I always have the same message.
    You can't desactivate it in the ecu engine ?
  9. #7
    Sep 2019
    rennes
    32
    Downloads
    Uploads
    I changed my additive ecu and it works wihtout dpfoff. thanks for you help
