Results 1 to 11 of 11
    Nov 2018
    Default BMW E82 120D 2008 IMMO issue
    Hello there, i have IMMO help needed, cut long story short, cant get comms with old ecu got new one and flashed correct Software... but obviously i dont have immo data, i dont feel confortable to remove the chip from board and read it that way, and solder onto new ecu or take them off and copy it, so what other options do i have ? from what i read, cant actually do a IMMO off, but maybe virginize? to then sync them together? find attached Immo data from read of new ecu
    thanks in advanced
    Shane
    Sep 2008
    OK you have 3 options:
    1: Get the data from the old eeprom.
    2: Virgin eeprom and resync.
    3: Immo off the ECU.
    To do option 1: You may be able to extract by BDM if the processor is half working and will boot mode. Else it's eeprom off and put into a reader.
    To do option 2: After reloading the eeprom you will need the BMW dealership tool to rematch he ECU to the CAS.
    To do option 3: You need to Bootmode the ECU to download the file from the internal rom and post it here for someone to remove the immobiliser for you.
    Cheers.
    brend's Avatar
    Oct 2015
    Same where
  4. The Following User Says Thank You to brend For This Useful Post:
    rafal (24th May, 2020)
    May 2020
    tot557545@gmail.com
    normus19
    Hello I can help you in Syncro new ecu and cas3 + ....
    flash file ecu and eeprom cas ori upload please for help you
    brend's Avatar
    Oct 2015
    Same where
  7. The Following User Says Thank You to brend For This Useful Post:
  8. #6
    Sep 2008
    Quote Originally Posted by brend View Post
    This is tricore ecu!
    Immo data in tricore eeprom not smd eep.
    Correct. Sorry it was early and I got edc16 and 17 mixed up.
  9. #7
    Nov 2018
    Quote Originally Posted by PsiDOC View Post
    Cheers.
    1, i cant do because i cant get any comms with ecu on BDM, unless i unsolder the EEPROM and i dont feel confident enought to do that,
    2, i have INPA if this helps?
    3, i have all files from ECU, can post if needed?
  10. #8
    Nov 2018
    Which tool you have for read from tricore flash/eep?
    Look better dump !
    This type ecu not have MPC only Tricore!
    To much ecu !
    All tool can do this which have sunhro function.
    it was read with Ktag,
  11. #9
    brend's Avatar
    Oct 2015
    Same where
  12. #10
    ASCM's Avatar
    Oct 2018
    I have bad experience with this type ecu touch with k-tag.After ori ecu read and write eep dump in tricore corrupted and car no start anymore.
    K-tag can't read from this type bmw ecu tricore eeprom and also write to.
    So....... find same another good one ecu programmer.
    Why ktag doesn't read and write correctly
    This type of ecu?
    Sent from my SM-J415F using Tapatalk
  13. #11
    brend's Avatar
    Oct 2015
    Same where
