Results 1 to 10 of 10
    May 2020
    Default toyota rav4 odometer problem
    Hello,i have a problem with a toyota rav4,the odometer remain in a fix number,the trip odometer only counts 0.8 or 0.9 kms in some times and returns to zero,previously the car underwent mileage correction..I tried different memory dumps,without any success.other dumps works too bad(no water temp,no ligths,freeze frame,alarms,etc),the only dump that works is the one that is currently recorded in the memory(but no counts)... also tried to change manually some hex values and the odometer value changed,but the problem continues.
    the problem is in the eeprom or in the main board?
    dash :denso 83800-42j80
    2013-14 rav4 A/T
    EEPROM 93C66
    jjservice's Avatar
    Sep 2016
    VIENA,AUSTRIA
    Default RAV 4
    try this dump mate.... hope it will be fine
    if you think i helped youkindly press REP+THANKS button
  3. The Following User Says Thank You to jjservice For This Useful Post:
    JETRONIC1 (24th May, 2020)
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Post original dump and I will fix it for you.
    May 2020
    hello ,I canīt upload the file,and no way to download the other posted too...
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    Quote Originally Posted by JETRONIC1 View Post
    hy
    must use only rar files zip , go to arhive
    regrads
  7. The Following User Says Thank You to catalinosonesti For This Useful Post:
  8. #6
    May 2020
    Default hello,this is the original dump, readed from dash eeprom 93c66
  9. #7
    clusters's Avatar
    Mar 2015
    Canada
    Looks like someone tried to make it 78236 but did it wrong.
    Here it is fixed, 78237
    By the way, this is read byte swapped
  10. The Following User Says Thank You to clusters For This Useful Post:
    JETRONIC1 (25th May, 2020)
  11. #8
    Sep 2013
    Too late for me.
  12. #9
    May 2020
    It worked fine this time! thanks for all
  13. #10
    Dear friends,
    can you calculate to 104xxx.
