try this dump mate.... hope it will be fine
Hello,i have a problem with a toyota rav4,the odometer remain in a fix number,the trip odometer only counts 0.8 or 0.9 kms in some times and returns to zero,previously the car underwent mileage correction..I tried different memory dumps,without any success.other dumps works too bad(no water temp,no ligths,freeze frame,alarms,etc),the only dump that works is the one that is currently recorded in the memory(but no counts)... also tried to change manually some hex values and the odometer value changed,but the problem continues.
the problem is in the eeprom or in the main board?
dash :denso 83800-42j80
2013-14 rav4 A/T
EEPROM 93C66
if you think i helped youkindly press REP+THANKS button
JETRONIC1 (24th May, 2020)
Post original dump and I will fix it for you.
hello ,I canīt upload the file,and no way to download the other posted too...
Looks like someone tried to make it 78236 but did it wrong.
Here it is fixed, 78237
By the way, this is read byte swapped
Please DO NOT PM me asking for help.
Post in the forum, that is what it is here for.
JETRONIC1 (25th May, 2020)
It worked fine this time! thanks for all
Dear friends,
can you calculate to 104xxx.
