Third party or smok uhds are able to disable this check on all mazda.
Reference code SKE 13E-01/02, 433MHz, price on AliExpress about 20 usd
I have programmed on the three different cars, 2x Mazda CX-5 and one car Mazda 6 and I get the same error on dash that can't be erased
I don't remember the error code but I can tell you that it was talking about was installed a defective component on the car
The all cars started normally with that error permanently on dash, the owners could go with the car as before
On the last car, Mazda CX-5 the client ordered an original key and after I did AKL programming the error is gone bcz I have removed the China key from the car memory
I think the flash memory from China key has an issue
Just tell them before hand
I do 20 of these sometimes it happens
Car works fine
Zero difference
Make sure customer is aware before hand
That is all
99% have no problem as long as car runs same
vialli (18th June, 2021)
Hmmm... is this (smok uhds) the same menu like CCC config list in AVDI where you can play with FORD internal configuration?
So it should be possible to disable this check with AVDI Ford and FORscan too?
How is this setting called?
Yes
Also vvdi key tool can now avoid this problem using their smart keys
autoTkey (2nd July, 2021), Locksmith Hungary (30th June, 2021)
does it work though
Tools owned -
If they copied it from KeyDIY (and I think they did) it should work like a charm.
