Results 1 to 11 of 11
    May 2015
    Greece
    Default Alfa 156 RNS Connect - how to read FIS Module
    Hi! How to read FIS module on Alfa 156 RNS Connect 7 607 271 022? Thanks!
    May 2015
    Greece
    Can anyone help me read the FiS module to find the code? I attached photos of the PCB.
    Raimax's Avatar
    Nov 2013
    LT
    The same as VW MCD I think near TDA7432D
    If you don't like it * close your eyes
    --- Geros dienos ! ---
  4. The Following User Says Thank You to Raimax For This Useful Post:
    alexandr1966 (26th May, 2020)
    May 2015
    Greece
    I read the FIS module as a VW MCD. Help me find the code from the dump 24c32.
    kappa1's Avatar
    Apr 2013
    RO-IS
    Quote Originally Posted by alexandr1966 View Post
    Line code is bad
    nelutzul40's Avatar
    Dec 2011
    Ialomita- RO-
    Try code 1159...................
  8. The Following 3 Users Say Thank You to nelutzul40 For This Useful Post:
    Albert G (26th May, 2020), alexandr1966 (26th May, 2020), kappa1 (26th May, 2020)
  9. #7
    kappa1's Avatar
    Apr 2013
    RO-IS
    Quote Originally Posted by nelutzul40 View Post
    Or code 3551
  10. The Following 2 Users Say Thank You to kappa1 For This Useful Post:
    alexandr1966 (26th May, 2020), nelutzul40 (26th May, 2020)
  11. #8
    May 2015
    Greece
    1159 and 3551 isn't correct!
  12. #9
    May 2015
    Greece
    Maybe the code should be changed?
  13. #10
    May 2015
    Greece
    In the morning, I unsuccessfully tried to decode this unit using Carprog. Perhaps after that the code line was changed!
  14. The Following User Says Thank You to alexandr1966 For This Useful Post:
    nelutzul40 (27th May, 2020)
  15. #11
    May 2015
    Greece
    SOLVED! Thanks to all!
