DTC?
Did he put diesel in tank? In doubt remove fuel and put fresh BENZIN.
Is oil level ok?
Is EGR stuck open?
Seized engine?
1.4 petrol. 2009 reg. 8fs engine. Car will not run,it turns over and tries to fire. Had New timing chain, as was diagnosed with this fault,but still the same. Had New spark plugs,tried a engine ecu, but still the same. Fuel is coming up from tank, spark is at plugs, timing is fine, compression is fine. Can anyone help with this problem please
DTC?
Is oil level ok?
Is EGR stuck open?
Seized engine?
Meat-Head (24th May, 2020)
Ok, for 1 thanks would say engine ecu plug full of coolant
So you done that
next step, for 3 thanks and 3 repoints
Remove one spark plug, see if will run on two
If not for 4 thanks and unlimited rep points and rimming
remove spark plugs and check 100% dry no wet. (Fit old if you have to)
refit, crank the shit out of it, good 45 seconds, as time goes by does it fire less?
then
1) check to see if spark plugs dripping wet
2) plug computer in read codes
after that
get gas axe and blow off the cat, repeat loose interest
See if egr looks like this.
Are fuses ok?
Does dash lit up?
It has a motor like this on rear of engine. But was told this was vanos valve
It's valvetronic motor and won't cause nonstarter.
radiosolutions (25th May, 2020)
Right been talking to few people on “pörn hub” we all agree
next step after checking spark color and length, do what “The Jam”
would do and take “David Beckenham” with them.
what did the squish gague go to?
Ok, so
1) cyclinder leakage test to determine if David Beckenham bent valve
after that if ok
2) torch it.
so next question is it possible the lumpy sticks have been transposed?
if wet plugs
a) no or interesting spark
b) excess hydrocarbons (choke all the way in)
c) not sucking oxygen
d) unable to fart
can you put piece of paper roll over exhaust and see if blow blow or suck blow
Plug in and check fault codes and live data.......check airflow etc.......check cam and crank readings. Post results.
