Results 1 to 11 of 11
    Jun 2019
    Default stage2 1749vb + downpipe
    Good evening, I need help to adapt on this map of a seat leon tdi 110 a 1749vb turbo that I have mounted. I can't get it to work well. Also the smoke limiter is not modified. I have linearized the map of 3 bars but I notice that they are missing highs. Could someone help me to go to stage2 ?.
    Thanks a lot.
    Cheers,
    chrisimerk's Avatar
    Dec 2018
    England
    do you have a 4bar map sensor?
    TUNING--FILE SERVICE--VMAX--EGR--DPF--FLAPS--LAMBDA--DTC--IMMO..........POSSIBILITIES ARE ENDLESS
    SPECIALISE IN TUNING DIESEL ENGINES
    (DEMON DEVELOPMENT)
    IF I HELPED YOU DONT FORGET TO HIT THANKS AND REP POSSIBILITIES ARE ENDLESS
    Feb 2017
    you need custome tuning !
    Jun 2019
    Good morning the map sensor is 3 bars with full ASZ intake.
    Jun 2019
    Attached reprogramming that I have made, the car is doing well but the turbocharges too soon and it lacks going well at high revs. I notice a lot of turbo pressure at low revs. I am missing something.
    Jun 2019
    This is the log channels 3 and 11. It could be improved ...
    chrisimerk's Avatar
    Dec 2018
    England
    Attach original, also the tune you have provided is let's say not good I'll make you a tune that will run off map so it will be a mafless tune will run correctly then
    (DEMON DEVELOPMENT)
    chrisimerk's Avatar
    Dec 2018
    England
    here flash this file and unplug maf test and report
    pass in pm
    (DEMON DEVELOPMENT)
  9. The Following User Says Thank You to chrisimerk For This Useful Post:
    davidbcn (2nd June, 2020)
  10. #9
    chrisimerk's Avatar
    Dec 2018
    England
    wow just stop messing with the maps your going to damage your engine and clutch your asking for 741nm and over 36psi boost and way too much fuel your going to blow something up and modified maps that you dont need to touch mate take my word for it flash the file i have provided and leave it alone
    (DEMON DEVELOPMENT)
  11. #10
    Jun 2019
    Good afternoon, here is the original file.
    Thank you very much for your help!.
    Cheers,
  12. #11
    Jun 2013
    EU
    The tune v2 is horrible. Manipulated codeblocks, both same id, lots of random changes, pure disaster, is impossible car runs fine on that tune. Better trash it and write chrisimerk file.
