Results 1 to 4 of 4
    May 2020
    Default Need Help please
    Hello everyone, I hope you can help me, I have a 2010 Acura RDX pickup (77960-STK-A210-M2) with the steering wheel airbag and driver belt damaged after a crash. I was able to program my eeprom with a clean file but the srs light is still on. I'm new to this (it's my first time), could you guide me if I'm doing something wrong?
    This is what I did:
    remove the car battery
    replace the steering wheel airbag with a new one
    I put an srs simulator on my belt
    remove srs module
    program the eeprom with the original file but cleaned
    I installed everything again, put the battery in and started the car
    and the srs light is still on
    Did I miss a step? Am I doing something wrong? Thank you
    right here right now
    Time to give it a plug in and read dtc's
    Sent from my SM-G950F using Tapatalk
    darrenhyland's Avatar
    Aug 2010
    IRELAND
    did you centre the airbag squib before fitting? Have you the old and new airbag module dumps so i can check?
    May 2020
    It is the same module, just clean the crash data, I already read the dtr and there is a short circuit with the side curtains. the strange thing is that they did not explode. they are intact. Thank you
